Today I installed a cluster with a tach. Wanted to stay with 97 as ford did that blue color for 97 only. I found a good clean cluster from a 97 explorer. Changed the mileage part and recalibrate the speedometer with gps.
In the past few weeks,
I installed a rear anti sway bar that I pieced together from 2 rangers at the pull a part.
Found a flowmaster original 40 there also. Cleaned that up and had it installed using 2.5 piping. I went back to original 40 vs the 44..I absolutely love how it sounds on these older 3.0's.
Had a rear solid glass installed.
It went to the mechanic for work to be done. Valve cover gaskets were done. Lower and upper intake gaskets replaced as some other things done for maintenance. The top end of the engine was cleaned. It will go back in soon to have the rest of the engine cleaned and degreased. Eventually will work on getting the oil pan gasket replaced.
Recently changed the transmission and rear differential using ford fluids. Used mercon 5 and 80-90.
Still doing this very slowly as the pain in my body is getting worse, always cannot afford the shop to do this. I still do things as I can, only not as I could in the past.
Regardless of the speed, it's getting done and that is all that matters.
Well, maybe that’s most of my vibration in the Choptop. Haven’t done a test drive yet. Still want to replace the hacked together crossmember, I’m getting a plan together for that, took some measurements today while I was under there. Also got some errands done, bought another blade for steel, dad’s 99 Ranger got inspected, and I grilled hot sausage for supper.
Also, unfortunately got word that a friend of mine and Paul’s, Michaela, well, her grandma passed this morning. Prayers please on that, because her family ain’t very good beyond her grandma. Her grandpa passed in a nursing home after getting the Covid vaccine back when that was a thing, not to start any argument, I’m just saying what happened. The rest of the family is mostly vultures and worse. One in particular is much, much, much worse. That’s probably closer than I should get to explaining so we will leave it there.
You don’t have to like them to pray for them. 🙏🙏
Changed air filter & washed using meguiar's gold class soap. Used invisible glass on all windows but the rear 🤷‍♂️
Prayers sent. 🙏
Yesterday I had the Choptop out. New trans mount didn’t fix all of my vibration issues, but it solved a lot of it. Gonna check my motor mounts and still need to make my new trans crossmember but it should now be good for highway speeds again.
Progress has been made on the front bumper for the green Ranger. Making two because Paul needs a bumper and it’s not that much more work to cut two of everything. Obviously not all of the pieces have been cut yet, and a lot of that has to do with the fact that I don’t know exactly all that I’ll need yet. But I’ve figured this much out and getting it test fitted will tell me what I need to do for the rest of it. So the next step is tack one together and test fit. There’s also going to be a strip of flat stock on the bottom in the middle that I don’t have yet. Trying to make this as simple and reproducible as possible.
I continued to try to tweak the AC on the Road Ranger. I blew the ducts out with a leaf blower, and I was just about to pull the squirrel cage to see if the screen behind it was all plugged up, or maybe reach in and see if the AC coil was plugged up.
Just before I did that, I dropped the glove box down just to see what I might be able to do from that side, and I found a big surprise. Some previous owner had cut a hole in the ductwork about 5 x 8”, and then capped it off with a piece of cardboard and a bunch of blue masking tape (Blue has the same adhesion as like spit). The piece was just hanging loose. I don’t know if I blew it off with the leaf blower or if it’s just been off all along.
I cut a few pieces of the aluminum HVAC duct seal tape after cleaning the surface of the box and put that on. Now I’ve got twice the amount of air coming out of the dashboard. I guess the problem is solved..
A granddad bought that truck new and did phenomenal maintenance on it, and then the last year he gave it to his grandson who cobbled up everything he touched. Fortunately, he didn’t have it long enough to do a lot of real damage before he lost his license and I got to scoop it up.
Just before I did that, I dropped the glove box down just to see what I might be able to do from that side, and I found a big surprise. Some previous owner had cut a hole in the ductwork about 5 x 8”, and then cap it off with a piece of cardboard and a bunch of blue masking tape (Blue has the same adhesion as like spit). The piece was just hanging loose. I don’t know if I blew it off with the leaf blower or if it’s just been off all along.
Assuming you don't want to find a replacement, perhaps some aluminum flashing, RTV, and some pop rivets might make for a better long term solution. But what you did will work for now.
Took my 97 ranger into the shop for smog, and it passed. I'm satisfied that it did. Now, I can cry later for the costs that my home state is charging for registration 😑. I truly despise what grover and his carb diet have done to my once great state.
Choptop was out and about today. Still got some vibrations, but it’s pretty tolerable now. Not exactly sure what the current complaint is, but I still need to check the motor mounts and build a new trans crossmember. Also did a little bit in the shop getting ready for some different things and buttoning up stuff for the rain we are supposed to get. Hopefully this week I can get the front bumper for the Ranger tacked together and start fitting it.
Big hold-up is trying to mount my bench vice, apparently Tractor Supply doesn’t carry fine thread bolts. My other issue is that I bought a drill/countersink bit. Came with no recommendations for speed, so I tried my HF bench top drill press on the lowest speed. It’s not happy with that and from doing some looking around, I’m seeing recommended speeds of 50-150 rpm… the drill press only goes down to something dumb like 720 rpm…
Event Coverage
TRS Merch
