lil_Blue_Ford
Cut & Weld
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Total Drop
- 4”
So…
This showed up for the green Ranger thanks to my buddy Paul…
Stage 2 kit, I’m going to combine it with the Jmod and whatever else I can find. Going to try to get some reference points established before this goes in so I can check after and compare.
And then when I went looking for an exhaust leak (I found it, couple loose bolts and a couple pinholes), I found a real problem…
Plus there’s this stuff…
Put my laptop on the green Ranger... it has some issues…
P0453 - Evap Emissions Control System Malfunction
P0455 - gross Evap leak
P1409 - EVR circuit failure
P0174 - Bank 2 too lean
P1891 - Transfer Case Contact Plate Ground Return Open Circuit
P1867 - Transfer Case Contact Plate General Circuit Failure
C1155 - Left Front ABS sensor failure
ABS doesn’t surprise me although I hoped I was past this problem. This was a problem I had chased repeatedly prior to the 5.0 swap so yeah. Guess I take another stab at it…
The transfer case thing is because I’m using the AWD case so there is no plug. Of course the AS-BUILT doesn’t have a way to turn this off in the GEM. So I either need a different GEM or find a way to resolve this. I’m thinking I might just need to ground one of the transfer case wires (currently I have a blank plug in the wire) and then it will just read as 2wd all the time.
The Bank 2 too lean is a problem I’ve had since I swapped motors. Same with the EVR. I’m not exactly sure what to try next to deal with those.
The Evap problem is new. I suspect I’m going to have to do some smoke testing. The main Evap line running from the engine bay back is all new, I did it in aluminum tube and fuel line. Theoretically that should have resolved any issues there. Gas cap seems to seal tight and I don’t see any obvious problems…
