lil_Blue_Ford
Cut & Weld
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Total Drop
- 4”
My parent's house has a two car garage, but when we were building the house I was told in no uncertain terms that while my parents are still alive, I will never be doing mechanic work in the garage. I get it, dad wants the garage spotless, and a garage that you actually work in, never quite is. In my parent's plan was a stand-alone garage/workshop in the neighborhood of a 30-40' deep and 50-60' wide, but dad got too busted up before that got built and it hasn't happened. We did build an equipment shed with a pair of garage doors, but one side is dad's one lawn tractor and accessories, the other bay has dad's skid steer (it needs some hydraulic lines and a little bit of other stuff).I feel you on that. Dad's got a shop with a 15x30 pad that I borrow for bigger stuff like the engine swap, but it's pretty inconvenient trying to work on things over there. Here at my house I've got nothing but dirt. Part of it is covered with a carport, but still over dirt. I'd like to begin the process of pouring a pad and putting up a shop and fortunately I don't have anyone to answer to on that. My dreams are about the same, concrete floor and decent sized garage, built for the future addition of a lift. Some place to work out of the weather, and so that I don't have to finish and/or pack up everything in one day. For my purposes something about the same depth and twice as wide as dad's shop would be great.
Unfortunately I'm probably going to have to tear out my kitchen to replace some flooring in the near future, which will probably put all of it on hold. Due to the way this manufatured home is built that means a complete remodel in at least the kitchen, maybe other areas if I find the damage is more widespread. So I've got to decide which comes first and how much of a bill I can afford to run up. I'd prefer to avoid touching anything like a home equity loan to do any of it.
I picked up a steel building, it's something like 18'x28' but I'd like to lengthen it another 8-12' at the minimum. Ideally I'd add a lean-to on one side. I'm not sure what I'm going to be able to get away with, but even if it's just adding 12' to the length of what I have, it will be a million times better than working outside on gravel.
I get it, I prefer to pay for stuff as I can afford it rather than owing someone for it.
