ForgedCrank
- May 30, 2024
- Indianapolis, IN
- 2.3 (4 Cylinder)
1994 Ranger 2.3 2WD, M50D , 3.73 diff
Hi guys, I've been running the numbers, but hoped you all wouldn't mind helping me double-checking my work.
My '94 has 14" wheels on it with some VERY old tires that need replaced. Due to the ridiculous cost of 14" rubber, I sourced some junkyard 15" wheels off of another 2WD Ranger of the same year. I dunno if it matters, but both are the ones everybody calls "Deer Print".
ANYWAY.... the stock tire size on here is 225/70/14-- 8.9" wide, 26.4" tall
I wanted to avoid as much as I can shrinking the sidewall down, so I think I've landed on this size: 235/65/15 -- 9.3" wide, 27" tall, same sidewall height.
So I have a few general questions about my choice here. First, do I have the numbers correct?
And secondly, the larger tires are an extra 1/2" taller and an extra 1/2 wider... do any of you think that will they pose any risk of rubbing on anything? And will the extra 1/2" width make them look too fat, or would that little difference be mostly unnoticed? I know my speedo will be off very slightly, and it'll cost be a little bit of torque, but I think with those numbers it should be minimal enough to not matter much.
Thoughts?
Thoughts?
