Hi, so I’ve got an 88, 5.0 swapped, the trans blew so I began swapping in a 1997 f150 M5R2 in place of the old fw146. I used flywheel and clutch out of a 95, 5.0 f150, the stock master cylinder out of the truck and the slave from a 1992 ford ranger because in that year they came with internal slaves and Mazda transmissions and it has the proper fitting to connect to the 88’ master cylinder…
I’ve got the truck all together now, custom crossmember and driveshaft made but no matter now much I bleed the system I cannot get the clutch to fully disengage. Any ideas? Thank you in advance.
