- Sep 22, 2007
- Michigan
- 2.9 V6
- My credo
- A legend to the old man, a hero to the child...
86 bronco 2.
Ive been battleing a few annoying little running issues.
First, it was a surge when warm under light throttle and a hard cold start.
Could not get codes from ECM.
Changed ECM with the one from rusty #2 (not the one its currently running)
The surge went away completly and i can (kind of) reliably get codes now. It still is weird on a cold start. It cranks, putters, dies. Cranks, fires up great, dies. Third try it starts but is still a bit weird if you dont let it run for about 30 seconds before giving it pedal. Warm it runs beautifully.
Heres the issue...
When i do KOEO codes it goes perfectly, i keep getting code 31 and 84. Both EGR related.
Now...when i do KOER it starts doing the testing fine. It revs up, drops down, shows "6cyl" on the scanner.
It asks for the "goose" test (code 10), i do that, code 31 comes up, and then the scanner loses communication.
I left the scanner on for 10 minutes and it still read 31, no square blinking to indicate communication. I repeated this to a Tee 5 times.
This almost HAS to be a junk ECM right?
I opened it up didnt see anything obvious. But i would think if it was wiring id get nothing on either test.
input?
Heres the issue...
input?
