lil_Blue_Ford
Cut & Weld
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Total Drop
- 4”
So Harry Ferguson was the one who came up with the 3-point hitch design, originally called the “Ferguson System”. He was trying to make tractors in Europe but had a hard go at things (TE-20 was the European version) and finally talked with Henry Ford to create the N series. Unfortunately Ferguson got a little greedy and started building and selling the TO-20 series in the USA and there was a subsequent falling out between the two. Ferguson went on to build tractors for a few years before selling out to the Massy-Harris company which then became Massy Ferguson. Other manufacturers couldn’t use the 3 point system until after the patent ran out unless they got authorization. The design of the 3-point lets a smaller tractor do the work of a larger one with ground engaging implements.I found a pretty decent NAA or jubilee for 1500 with a front end loader. Guy says it runs good and works well but it needs a head gasket.
The NAA's were OHV correct not flathead like the N's?
The fergusion TO's were on my radar as well since yes they are basically an N ford. It seems like every single one of the TO's i find around here are beat to within an inch of their life.
The older cases and deeres tend to bring good money around here. I wasnt sure when they switched to 3 pts
Another fun fact, the famous exploration (Sir Edmond Hillary’s) to find the South Pole used TE-20 tractors to drag their supplies across Antartica.
