lil_Blue_Ford
Cut & Weld
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Total Drop
- 4”
So, option B can technically be done. I have done it. However it’s a little sketchy and often you end up having to loosen the bolt for spring and to be really honest, not only is option A safer, it’s actually easier. Also gives you the opportunity to check and/or replace the axle pivot bushings when you do that.Oh wise ones, how do you….
97 Ranger 4.0 2WD.Radius arm bushing
A: I looked at the videos on line, and a guy in a professional mechanics uniform, in a very nice commercial looking shop, had great detail on how to change the bushing by completely removing the radius arm.
B: Then there was a shorter video, with a guy who looked like me in a grassy worn out T shirt, who let the pressure off the spring, removed the shock at the bottom, and then used a ratchet strap to pull the whole assembly forward so the radius arm would clear the hole.
I’m a pretty good turn wrench, but I’ve never done this before, but I’m not above cutting a corner or two (as long as I don’t scratch my Rustoleum).
Am I OK doing procedure B?
I’m good at turning wrenches, but please fill me in on the pros and cons on what to do and not to do so the spring doesn’t knock my feeble head off.
Please also let me know how this might affect my alignment…
I don’t particularly like doing it either way. I’m lazy. Fortunately for me, supposedly ride quality on the TIB/TTB suspension, as well as articulation (suspension flex, and this is the well known and proven part, ride quality I’m not entirely sure on if it’s in stock form), can be improved by doing extended radius arms. I like using Ballistic Fab‘s Ballistic Joints and some 2”x2”x.250” tube for building them. Greaseable, adjustable, rebuildable joints. Much easier to deal with.
Alignment shouldn’t be significantly tweaked unless everything was in really bad shape when it was last aligned, but if that was the case, the shop should have told you about needing to fix that stuff before it gets aligned.
