- Aug 24, 2007
- Third rock from sun
- 2.5 (4 Cylinder)
- Tire Size
- 235-75-R15
- My credo
- None at all.
Yeah, @ben_2_go, I wasn't trying to say that was your problem, just giving an example of how it could become clogged with the system being sealed.
I'm on my phone and can't see what year you're working on, if it says anywhere, but are you aware that on some Rangers the blend doors are vacuum controlled? Maybe you addressed that already, but it's the first place I'd look. Not sure, but I suspect it defaults to heat and the vacuum pulls it to open.
2001 2.5L. I checked the blend door, it's moving. I can hear it set between warm and cool. The temps changes from really hot to ambient air temp. Good call, tho.
@ben_2_go - if the pressures are correct but the compressor constantly cycles on/off, I would replace the high pressure switch. If that doesn't fix it, then you have a high side blockage somewhere - could be a plugged orifice tube or somewhere else.
That's what I am leaning toward.
