Good to know that it will hold up and that’s a pretty valid point.
Yup, that’s what I can find that will work without modifications.
Correct again. I have after a lot of searching found these from one source for 1-5/8”/1.625”, but only in 0.095 and 0.120 wall, which my tube is 0.134 wall so neither work without modifications.
So the choptop was built as a road legal mild-moderate trail capable rig. My answer to some trails not being accessible if you had to tow your rig there. It’s also been pressed into Daily Driver use several times and is a fun thing to drive around because it gets attention. Since it’s not really built for the street, it takes some care and respect to drive on the road. There’s always the chance of some other driver screwing up though. I like the thought of welding the connectors half and half if I go with the sleeve type, did think of that.
I was kinda hoping someone on here could either tell me where to find what I need or be able to turn some down for me. I’ll have to check local again too. Last time I visited this idea I couldn’t find an answer.
Yeah, moving the parking brake pedal has been considered and I’m really not opposed to the idea, just have to figure it out.
I worked the math out for a 1.5” 0.120 wall and it’s about a 1.26” ID. The 1.625 X 0.134 wall is 1.357” ID. So still doesn’t work out.
After afterthought. Again in the category of there are no stupid questions (or suggestions):
Do you have a drill press? For some of my screwy projects I’ve had to “turn” down the OD of a cylindrical metal part/piece. After busting a few things and fortunately not my fingers, I came up with this:
Using a stout threaded rod and a couple cone shaped wood ends, I pinched the piece so I could spin it on the drill press.
Trying to then cut with a tool never worked, too unstable. Then I had the brainstorm to put a rotating drum sander in my hand drill. With the drill press spinning, I held the hand drill drum at about a 45 degree angle, moving it slowly up and down, I could slowly grind down the outside.
Once, when I needed a piece precise, I ground only until it was a little oversized, and then I shifted to sheets of emery cloth, starting coarse and shifting sequentially to fine. I constantly checked it up and down with a digital caliper and worked it to pretty good precision.
If you go slow, you shouldn’t heat the metal. It was a little tedious, but considering your situation, budget, and desire for precision, it might work if you have a piece with the right ID that’s too big OD.
To make the wood cones, I used a hole saw a little bigger than the ID and used the cut plugs, I used a threaded rod like before, and just used a coarse file with it chucked in the drill press. After a couple tries, it was pretty easy to center parts.
Of course I save all this junk for the next time in the shed of miracles, but don’t ask me where they are!!!
Hope it helps!
& BTW, I trimmed the living heck out of a dozen of my trees up about 10ft, in front with my 10yr old 110v harbor freight chainsaw and my +/- 69 ft extension cord (started at 100’, but after 30 years, I’ve cut the ends off 20 times at least). Way more Macho than my Hobby Lobby glue gun, huh? Are you proud of me?
