James Morse
1997 XLT 4.0L 4x4 1999 Mazda B3000 2wd
- Aug 31, 2021
- Roanoke VA
- 1997 and 1999
- 4.0 V6
- Tire Size
- 31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
- My credo
- The perfect is the enemy of the good.
so it seems like no good solution. but it only freezes if it gets wet, right? That issue not really apply to me anyway.
I don't get about the rubbing, what kind of situation would have it rubbing? I mean, if you wind it on a winch it rubs itself, but otherwise.
yeah Blmpkn that is a very good question. I guess my thinking went like this: I don't have somebody to go 4x4 with, yet anyway, so I'm going alone. the road I'm currently working to do the whole thing, there's not much traffic, like, we stopped the other day and got out the cooler and had lunch and looked for fossils and no one went by. so if I got stuck, I could be there a while. And even if somebody came by, would they have equipment? No way to know. Would they try to help? Probably... just based on a loose guess.
Then I ask myself, when would I get stuck. First of all I would avoid it, so let's say I had equipment, and never got stuck, that would be great. I'd consider it not a waste just like having insurance isn't a waste because if you ever need it, you're happy to have it.
If the chance is small of ever using it, logic would say, sure, if straps and a come-a-long would work, do that, at probably a small fraction of the cost. I still have to attach straps to something - the frame I guess. That should be do-able. That's possibly an elegant solution if it gets me out of putting on front and rear hitches which is expensive and just adds more weight and might decrease approach/departure angles a little.
Whatever you have, there has to be an anchor point. What if there's no solid tree close and no other vehicle? Seems like you're just stuck until somebody comes along.
How would I get stuck? I think the primary issue is truck hangs up trying to go over a rock that is too big. There's mud around, but, I'm not planning on driving into a big pool of it. Mostly it's short stretches and so far not deep.
Obviously I don't want to hang it up. If that happens there's damage somewhere, maybe it's scratches, maybe you dent skid plates, etc. Personally I'd like to have rock bars, have to research it a little more and get advice
93-11 Ford Ranger Weld-In Rock Sliders - Affordable Offroad
that seems like once they are on there you never can take them off but if they really work that would be way better than other kinds that are really just steps not rock bars.
if they save from dented rocker panels which I see could easily happen they would be worth it
Anyway that's my thinking fragmented as it is. There's high centering, there's maybe rock bars hung up (maybe never happens?), there's mud, but probably not, there's maybe stuck in 6" of running water because I didn't see a big hole in the creek bed. That's all I can think of.
But if a come-along strap breaks isn't it a similar problem? Can I get enough leverage to move the truck?
I have only been out like 3 or 4 times mild 4x4 (some sites call the road "moderate") so I'm just going by what I come across in the kind of thing I like to do which is you can get to a place and look at it and go, well, I think it's fine, but, I'm not really sure, and what happens if I hang up the rear differential on it hard enough the fronts can't pull it off. Then I'm screwed. If there's nothing close I can hook to I'm screwed too even if I have equipment. So I tend to err on the side of caution but where is the fun in that, plus, I'm like sure/determined I can go thru this road I just have to be careful about it. It's actually the raison d'etre for the '97 because I started going up it in the B3000 (rwd), got not far, and said to myself, you need 4x4 for this road. I love the '97 so I'm not against spending, hopefully wisely, some money on it.
It seems to me like rock bars, if they are welded to the frame, you could jack on them, you could pull on them, right? If they get banged up badly, you can replace them a lot easier than replacing rocker panels. They look rugged.
I'm just thinking of places where you have a choice, you can plan to get your tires to go over the high point so you don't high center, but you might by doing that be close up to rocks on the side. I could foresee all kinds of situations where they could save you body damage. Unless I'm reading that wrong. They'd add 80 lbs, not horrible.
There is also call a tow truck. I'm just not sure if my insurance would pay for going way up a fire road past 5 creek crossings. At probably $2/mile for a tow, it wouldn't take long before the money would be better spent avoiding that nightmare. And sure, there are lots of other kind of failures that will leave you stranded but in terms of truck is stuck on/in something it'd be nice to have a backup plan in mind.
