94' Ranger
- Jan 17, 2021
- Southern California
- 3.0 V6
- Tire Size
- 15in rims + Falken AT3
Yeah, that what I was referring to..small flakes of material separating from the lobe, they have to go somewhere & that usually is the pan & then sucked up into the pump & then on to the filter where one can hope that's as far as they go (but don't bet on it). also seeing some corrosion/pitting in there as well. Has this engine been sitting unused for some time? Seeing as you're in Cali I would not have suspected moisture corrosion.
I worked on my truck inside my garage for about 8-9 days in mostly dry weather (just some morning dew), I would be very surprised if moisture corrosion was the culprit here.
Since my oil and coolant are mixed I need to clean everything out as much as I possibly can anyways, should get the metal debris out of there. Once it running again I plan on doing 2 oil changes within the first two or three days of running, maybe another a week later just to be safe.
