- Nov 20, 2021
- Wilmington, NC
- 4.0L
- Total Lift
- 4” suspension
- Tire Size
- 265/75/r16
- My credo
- built her in a storage unit
i thought i may have blown a head gasket on first startup or intake manifold gasket due to lots of smoke on first startup, (was also revving it to 2500 to do cam break in so this may have had something to do with it) so i went through some tests
i did a dry compression test with the results of
1 - 163
2 - 170
3 - 170
4 - 160
5 - 155
6 - 155
but this didn’t rule it out completely, only partially
second i did a coolant pressure test
i didn’t know it was supposed to be 13psi i thought it was supposed to be 15-16psi so i did 15 psi on it and it held the pressure for 20+ minutes
is there anything else i should do before running it again? or am i good to go? because in my mind that completely rules out any coolant or head gasket leaks but im not sure, also when i was doing compression test no liquid came out of the cylinder at all so i think i’m in pretty good shape, i’m about to prime it anyways cause this gave me time to get a priming tool so i’m very patient right now, any more input would be excellent and very appreciated
1 - 163
2 - 170
3 - 170
4 - 160
5 - 155
6 - 155
