- Nov 20, 2021
- Wilmington, NC
- 4.0 V6
- Total Lift
- 4” suspension
- Tire Size
- 265/75/r16
- My credo
- built her in a storage unit
i believe it is the intake manifold gasket, because it took so long to crank i’m assuming it was pulling in a ton of water/antifreeze i though i did a pretty good job of installing it but i guess not, brand new head gaskets as well. any tips for when i redo this gasket (probably this weekend) i did the ttb on the curved edges on the front and the back but other than that i though i did a pretty good job, seemed like it was pulling in a ton of water so i guess i messed up pretty bad, pretty sure it’s not a head gasket as i did those to a T with new bolts and the oil is not milkshaked definitely did not take as much care on that intake manifold, also used an intake manifold from a junkyard truck instead of reusing mine because i broke off a bolt or two for the thermostat in the original, think it has anything to do with that? i still have it and can use it for the reinstall but i’ll have to remove those bolts maybe they’re not lining up properly because it’s not the original? not sure any help would be appreciated especially tips for after i get it put back all together and go to crank it.
