lil_Blue_Ford
Cut & Weld
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Total Drop
- 4”
I have an Ammeter gauge that I got awhile ago for my 2000 Ranger. It got mounted in the truck and more or less forgotten about because I couldn't decipher the instructions that came with the gauge (they give you 3 or 4 wiring options depending on how your vehicle is configured and make no attempt to explain exactly why it works plugging it in between wires for the horn or starter).
So if anyone knows the proper way to wire up an Ammeter gauge, please explain things to me...
The truck is a 2000 Ranger, 3.0L v-6, 5-speed. The Ammeter gauge I have is branded Summit Racing.
Also, after reading about the dangers of running an ammeter in a vehicle, does anyone have suggestions for fusing it in hopes that should there ever be a short, it would pop the fuse before causing a fire? Fuses are cheap, fires are expensive.
