LF Rear Diff Fill Plug Tips & Tricks
If you put anti-seize on the outer half of the threads of the new plug, you won’t have to worry about it next time. Easy peasy.
Jazzer
well yes, but if you get your truck 10+ years after it was built and no one else had ever had that plug out, and especially if your in the salt belt, not so easy.
Poor man’s never seize: teaspoon of talcum powder with a Half teaspoon of bearing grease and a squirt of penetrating oil. Mix & apply.
Those three things cost more than actual anti seize lol.
Treats hemorrhoids, too... ;)
If you don't pull the plug and check the level every time you service it you're doing a lousy job. It doesn't need never seize if it's removed a couple times a year.
EVERYTHING needs antiseize. :ROFLMAO:
I use antiseize like hot sauce, I PUT THAT **** ON EVERYTHING!
Do not put it on the underside of your co-workers passenger side door handle. Once his wife gets that on her hands, clothes, face, etc. And finds out it doesn't wash off easily, he will be dead and you will be next on the hit list.
there is a story in here somewhere that needs to be told...
AJ
Anytime I drive someone elses car I wipe my boogers on the hood release...
