Turbo truggy
That's going to be nice having the trans up so high! That cerekote looks killer as well! You are making me want to tear my rig apart and make it look nice lol
The biggest problem is going to be hood clearance I think. Time will tell. I've cut most of the floorboard out now and will build a new one once suspension, drivelines, and exhaust is in.
I had a little free time today so I built the passenger side motor mount. I modified the engine bracket to save some time. I need the mount higher than stock so the suspension link doesn’t hit it.
tGN7wMP3J406rpJ0eNFx5PvqEyT7yEJZgCHZD3Wcfb_suotq-mgBSRJGA6S6uXWBtnjHuDJO43mxr0DEnN7yh5T3OyZcguxNHFl1iGfa_f6EYPAMIa0E6SbTtKga0hRnGAxRqLaETg
0JqFId3NbmN6zOiF1kyuHvaT34oSxp7RPyebDAZnwdyd9h5JrUaOqlWxUKv_fvIKzw84VJQNlk6DAa_RzNafhdLor-WG3wjlcR7Vog1eaSjG3wLSgDEvT7tPvPbb4l3tlvhVDhp1QQ
tnif9dt1DntPlgtGDUJa-MVmnPmYcqib4pJUpI5Zq0lO4OdQRJxi16MJgwSfZvhUQp-0y9ENRzJtKx2dgiAUYUUFHENxICbEXH87b4JuPkDB5ZFDSKnnLLXNkuhXfWWKxsv-kelw5Q
FwYNrS6UpV33dBR1o47678f1U3vhSOIIMfCrS6JvsnC2l2lWKcm3dsU0sVjtc8LoifnNLCdaVmMj-eCLCSF-Ch1B6Nsr7orDSmdyrwzkm01ocksw2GLsh0EExjgrV8ajl0aoVYfZZA
That motor mount is nice, great fab work!
Thanks. Progress has been slow the last few months so this is probably the most boring project on this forum. Things will speed up once I can start on the suspension.
Never thought to look for this project over here too! Lookin good as usual.
Pretty much the same stuff. I guess I’m an attention whore. I almost went with a split port 3.8 and M5R2 instead of the 2.3t.
Who's the bigger whore? I have like 7 projects on tf and like 3 here lol
I was wrong. I did have to modify the drivers side bracket
vAz8meMASoC3L8frvNxYoPZ9X7VpOPtPEmfhvf74Fry8C6nYwINahO0sgmIfmzLPjSYTrIFBD4_DnweUEUSdJDxedd0SUms-P8m6OF9Y-EL8-0Rh_xtgm-RBIQ30VpxNHK63we_Ddg
But at least the motor mounts are finished
FcVXGsEMQQ5ph_Wql21jGk_TMAd_M9-ktu_8BYHq-Yz5YvNq6ql20UNISb37rQCvm3e1ZUPt-KZgPgSBqTgyToT3hdyIJH7cmkGUGfwDD5aHbSPvEUYpvSK8B3wmJ7W8f1QaKvWYug
Made a little more progress today. I built a temporary transmission crossmember. I won’t build the permanent one until the suspension is finished beacause the frame brackets will get tied into the suspension mounts and will have the mounting points for the skid plate built in.
mg5ebzeUFvAFxAhFTIQDngudfWbwKDKpUJMWG56vtQZ7uyJy28FEPCyIYjo75KGS0JmJF2fgD3je6_5MkUd5JuVDrJI9MKRIePFT7QzaXa0vJmSU0nQKhpOa3rYXEK8SHQEFg7NcEQ
I slid the front axle housing under so I could start daydreaming about where all is the links will be located.
-lzbTpjSAx9m4XQJZ7vPW-jZkEI1WX-k0gwcNNcSLWPNC186uYjmcbPVhq0afeS5uCxF-yMgTNMSy4T_51e0TOI6bfdktbqK1Eo9gmIdIcNAGXNKMKnhoe0vmSuwoNao1pC1kZIbWQ
B3AacsehlfZpdr8780YSSIlRYHZ7U6I68eJEDduXRaVQR6lUsaExRP5F3XGncVeiCgjq3xEl5wsA0okq5UfYg7WIBwm5uT1vlXkes3byvs8GrGgcv9fqmXQZpcxLPbaCFMM_XGOC1Q
Fitting a double triangulate 4 link up front isn’t easy, but it looks like it’s going to work with this frame. It’ll be nice to not have a panhard.
I started tying the front sect of the rock sliders into the body
NGSPlTw7l8cn3SpkCAPoZigJBaZcg6Vls5JZmu2XrGzGma8N3HTzx1XZlDIK8ZR2qxWlmZaE0dTyTEaTkfOFTJXLn0g6rPJEZOZIAGEaTCI2l9wEBSAacROM6edx5WK11hPw83iu7w
It’ll be a while before I weld the exo cage together, but I wanted to see what it will look like
N4iywtHrhHp5A5QPOv_41QbVnygqT6mvmkyantO3IJVrq6L4-R6OTsAbAti8I5lVxgOoklMcMQte-_nlp4aSS_-YnOOH_6BTCzfjykf4dXQDQZS2PCSLu9H1S7WG4LLAcpmF6rFPQQ
Once I get the driver side finished, I can start building my core support.
Love how you did the A pillar
Thanks it’s not something you can get away with if your frame, body, and cage aren’t all integrated, but it really stiffens up that area. I’ve noticed rigs hit thst spot on rocks and trees a lot. It will gat tied to the dash bar once it’s in.
Got a few more tubes cut and tacked in place tonight. I only had a couple hours after I dropped my kid off. Progress is progress.
lIdavT1-2Y2_UG7N0Y-LAyYFSZuwNNPGAI5DOQS7xBXIhM6A1dmC9v6hm-2UmW6PhhOh7SK3CdXQmYxszO-bMsKMzdOAgTrWv_ZvGNmowNzSWZr4Y8zdWGjIwflTfVmZwWqD22id2g
kY8Dc3EtuHnbcplqxrlXw8YS5MAFPJq0r3b1QWWjZ_rxxwA9eAJI6eiOQ0UUA0DslPBHSibwjfMx8j-5Fl7wQY9G7CvZ7PBmQUhPoKrFTCPp9nCvQIiH5nUI-RRedAZ8u1ze9Qlayw
Then I slapped the doubler and transfer case on the back of the transmission. I had to shim the temporary crossmember up about an inch to get the drivetrain where I wanted it. The transfer case should make a nice arm rest.
DFWnUa_CzNg5er2h5unubFMU_e-FiT2jetn1hIXV9CzcKawRupD9B3BNbkl4AMb6U6tMrgXSypHWJfwtPUSpX7GEbG-U_hpB9prbyF7OuibmPUMBdVHonBpuPO51PL0S-HQv5E15Tw
It looks like I’m going to have to move the front axle forward about 3 inches from where I had it sitting so I don’t destroy my oil pan. This creates two problems. It might put my tires into my turn signals. I can always put LEDs in the bumper, but the original plan was to keep the front end looking like a ranger. The second problem if the length of the driveshaft. I need to do some research on this. I might have to go to a two-piece driveshaft.
So... anyone here run a / piece driveshaft?
Got a little more tubework done. I’ve had the fenders and grill on and off a lot to make sure things fit right still.
LIaCcnoabM5A0LHrmr7a-eBQrJlUYp43snw_-p_z1JJTuM79UmzdUBcHslXVWD24vhK3Ny9veEsyQwBo3BchimyQzaArKJAF2Yi9jCJax3Rzs66HeF1268sDmQXAc7d0Q-2rNFH6wA
I’m still not 100% sure how far I’m going to move my axle forward. I played around with ride height and wheelbase a lot last night. I’d like to keep the factory headlights, but I’d also like to have a low center of gravity and not kiss my crank pulley with my steering ram at full compression.
5r8QSxhMfEgTAsRpRWpwkwl-DiG_GNuLE6FuBdAETVYbfmhz-wpVHUDSEQ5Jc4NMKAhPXhCz6qEvp3cqyvoutZpHJAaNkPpKch--YwjTW2YKuDa7nqx1ka9sYa-Okv28twv3q6EJjg
Cm8c1ItiIOxMxD9oHaApaMe0ZgbmpQrBnLnyNiZCldhFxOU7ifIYJNvjZFMtBzK780bj_wy1iB_x6CEyshFu4e3qXrM0CYWvGSdoZWsEv_IVkUT3854jqT5hx_UFNtxApofWEst7aQ
