- Nov 5, 2015
Ford 8.8 swap questions
A coworker has just informed me he will be picking up a Ford explorer 8.8 rear end to aquire the L/S style carrier. He has asked me if I want to get a good deal on the remains, which will come with an open carrier and 4.10 gears. Here is what I know:
-From a newer explorer
-Has disc brakes
-Open carrier with 4.10 gears
-Coworker will be taking the pinion flange from it to mate to his existing drive shaft.
-Looks like it will be ~ $150 CAD
Should I do it?
Right now I have a 7.5, no idea what gears, 2WD, no idea if my driveshaft will work.
I own a MIG welder, and have easy access to a TIG machine as well. I know I will need to cut/ weld at least the spring perches.
I looked through the axel swap section, which was helpful. I'm just not sure if this is a step in the right direction, or just opening up a whole other can of worms...
-Has disc brakes
Should I do it?
