houlimon
truck runs, front lamps work when i pull the knob, blinkers work. when i push the nob in, my tail lights stay on draining my battery. not sure where to start...
is it the tail lights? or brake lights? if it were taillights the instrument cluster would stay illuminated too. because they are on the same circuit
I have seen when the pedal pivots wear, and the pedal under its own weight sags just enough to trigger the brake lights. this can be verified by lifting upward on the pedal and seeing if they go off
now im dealing with reverse lights not coming on when Ishift into reverse
