- Nov 6, 2012
- Age
- 31
- San Antonio, TX
!!!!!! My wire harness has no parkneutral switch input and im confussed on what i need to keep !!!!!!
still searching for a damn tbi
started pulling apart the wiring harness and removing the junk, hope i didnt need the AC signal and control since mine already works
the jnkyard said it was a 93 but the door says it was a 92, the wiring harness colors kinda match the 1227429 ecm but the ecm is actually a 1228062. should i just hook up the signal from the a/c. ill have to solder the wires back on. damn wish i knew this sooner, assuming only makes an a$$ of your self.
it came out of a s-10 (thats the pickup right?) and its a manual 2.8
Its low enough that non-fuel injection fuel hose can be used. I bet that's why you are asking
Thanks for the answer and yeah that's why I asked, also how did you go about attaching the return line to the smaller of the two metal pipes on the new filler neck. It looks like jbweld
Thanks for your help so far kadams![]()
There is a lot that I don't know, thanks for enlightening me.
Here's the wiring diagram, you're mainly looking at the 3 Amp Crank fuse and the 10 Amp ECM Fuse.
thanks, these will help greatly. i see a wire for diag enable A9. what it this used for? also can i get a interior digram of a 84 2.8 bronco2
