build thread for 2.8 carb to chevy tbi.
the module that is bolted to firewall above the distributor, i got that little box its in there,
yeah, it bolts to the firewall. that's the one :icon_thumby:
would it be practical to mount the distributor module in the cab?
that is what rico did, it is right next to the ecm in the cab
wait scratch that, i thought you were asking about the est module.
you want the distributor module to be somewhere that the heat-sink you build is going to get as much airflow as possible. and inside the cab doesn't get a lot of airflow
Here's the ecm and est.
Does the pump need a primer pump, like using the stock 2.8 mechanical pump to feed the high pressure pump?
Yes, run the 2.8 mechanical pump into the high pressure pump
picked a pump off a 89 f150, with lifetime warrenty:)
also does anyone know of a cheaper one-wire alternator that is like 130-170 amps than this?
the picture is linked to summit
Update:
still searching for a damn tbi
started pulling apart the wiring harness and removing the junk, hope i didnt need the AC signal and control since mine already works
question how much pressure is on the return line?
Its low enough that non-fuel injection fuel hose can be used. I bet that's why you are asking
