Snoranger
Professional money waster
⭐Supporting Member
💻 TRS Socials
ASE Certified Tech
TRS 25th Anniversary
- Nov 25, 2007
- State - Country
- NJ - USA
- '79,'94,'02,'23
- Vehicle
- Ford Ranger
- 2.3 EcoBoost
- My credo
- I didn't ask for your life story, just answer the question!
Other way around. The frame is almost cut in half by rust on one side on the green one (picture at night) not to mentionned the box is like a swiss cheese and the cab is sitting on the frame. I can see through the floor on the passenger side just like the flintstone's car.
The black one has a lot of bling bling i will throw away but she's a solid truck and already have a 3 inch body lift. I've bought used goodyear duratrac in 31. It's sitting on skinny winter tires right now.
Also: I've read on another forum about bigger turbos. One guy said, well i'll quote him, tell me what you think
For turbos a lack of boost is what causes high EGT's. Anything you do in an attempt to reduce turbo backpressure (i.e. bigger turbo or bigger exhaust housing) will reduce boost and increase EGT's.
To get EGT's down you need a smaller exhaust housing to spin the compressor harder and generate more boost.
??? I tought it was the other way around? Like i said before, i'm new to turbo diesel stuff, but generally, guys open things up to get a better flow, At least, on gassers.
You put a bigger turbo: It spools slower than a small one cause it needs more air to do so. But once it does you got a lot more air flowing and a lot more pressure. If you got a good p-flow and an unrestricted exhaust the limit sits on the volume of air your intake and valves can flow? And the pressure the head can handle (head gasket, head studs, etc?
How do i calculate the 4d55 head flow limits?
This is a bit what i was saying about the internet. I read a lot like you do, but once in a while i get conflictual informations that gets me thinkin... What if that one guy was right? So it's ok for a starting point but i'll have to do the maths by myself.
Here's the conversation i came across. And seems that the guy that i've quoted got a lot of posts on that forum. Not saying the number of posts means alot, but at the very least he's been around for a long time....
http://www.4btswaps.com/forum/showthread.php?17865-4D55-Ranger-Tuning
Listen to Dougal... He knows what he is talking about.
