ericlerouge
Eric: yeah ive heard they'll do 20psi and gauges are a must with any diesel everyone knows that so it goes without saying haha but im not the biggest fan of my 4.0 i grew up on diesels haha i just dont really like gassers
also i found out the both of the motors are 2.3l 4d55's he meant that the one that runs has the turbo off of it because he used it on something else i just miss understood him.
First, not everyone knows everything. I told you what i did cause i thought it was a good lead. i don't know what you know or don't know, and frankly, i don't really care. I told you, just because just the boost and egt gauge cost me 300$. Add that to your 600$. add another 100$ for the clutch and slave, another 150$ to upgrade the cooling system in your truck, another 80$ for new glow plugs, another 40$ for an oil filter, because, yeah they run for that much, a rebuild kit for the turbo is 85$, motor mounts? about 30$ if you can find the good ones. on your truck, you'll have to: move the crossmember an get your driveshafts modified, about 150$ Those engines sat there for how long? can you see,, ear one run? injector pump probably leaks if it was sitting there for a while. both trucks i had with that engine did. with those numbers i'm at over 1500$ and you still don't know if the engine runs or not.
Do yourself a favor and buy a compression gauge and check the compression on the engine. you just need to hook up a battery to the starter. (i know:you already knows)
When people are trying to help you the best they can, do you always laugh at them in the face?
