Gen. 1 seat track bolt to 2 gen floor?
Kodah
10+ Year Member
Will gen 1 ranger seats go into a gen 2 with no modfication any help much apperiate
Koda.
I put a Gen 1 bench in my Gen 2 that originally had buckets. The front required adapters to be made as the angle was wrong, and the rear needed new holes as well. In short, nothing lines up.
i cant imagine they would be different, the cabs are nearly identical. they are different from regular cab to extended cab though, was that your problem? i would think that as long as the cab style is the same, 1st and 2nd gen seat tracks are the same...
If this helps...
I put a set of second gen bronco II seats into a first gen bronco II. The front seats almost lined up perfectly, if I remember correctly we had to drill two holes through the floor for the seat track to work on the drivers side. Possibly the same for the passenger as well, ( this was 5+ years ago so I'm a little foggy ). But in reverse it should work for you with only minor adjustments...in theory...
Koda.
Pending cab differences they will bolt right in.
I have second generation Ranger brackets in my first that had a bench, I had to drill the four inner holes but they were even premarked by Ford.
I recently took buckets from a 92 Explorer (similar to a 92 Ranger) and they bolted right in to my 88 Ranger...absolutely perfect fit...
So, yeah, they should work if the cabs are the same (regular vs extended)...
I know when I had the regular cab 88 with a bench seat I had to do some slight mods on both sides to get bucket brackets from an extended cab to fit...but it worked...
I'd suggest using grade 9 bolts regardless...and if you have to drill holes...you might want to weld some washers or other support material around the holes if it is not pre-drilled or otherwise supported by extra metal.
Even a strip of angle iron might work between the rear bolts though...just some extra metal to stop it from ripping through the floor boards in case of an accident...
I don't know if using a real hard bolt is a great idea. They are stronger overall but are more brittle and break easier with a sharp impact... which is what a bolt will go through in an accident.
Unless Mark is talking about a Metric grade 9.whatever which is between a standard grade 5 and 8. I wouldn't go any harder than a standard grade 8 and an 8 is plenty hard.
You don't need to weld the washers in, they won't go anywhere unless the bolt breaks.
Ah, yes, grade 8...sorry...not sure where I got grade 9 from other than high school...
Grade 8 is the law in Canada for seat bolts...I checked that one with a few sources because the lesser grade were less expensive to buy...but the stronger bolts stand up better to the sheer forces during an impact...from what I was told by a guy at Brafasco (bolt manufacturers in Canada).
I think I did read somewhere recently that grade 8 bolts were actually less strong in terms of sheer force but don't remember who posted a link to some website...something about a hoist and using a bolt to secure the chain...
Both were regular cabs. Bench seat from an 83 going into a 92.
Found another reference to it.
http://www.therangerstation.com/forums/showthread.php?t=5487
My second generation seats bolted into my first generation without issue at all. I had to drill the four inside holes but otherwise they pretty much dropped in.
This pic shows the added crossmember stuck on top of the Gen 2 floor:
Early trucks did not have this, but I don't know how early they changed.
Maybe the change happened midway through Gen I?
Neither my truck or the second gen I pulled the seats out of had that...
I wish I would have checked the year but the donar was a beat down stock blue 4cyl, 2wd shortbox truck with a trashed blue interior and nasty 60/40 seats. It had the 2nd generation nose, dash and the tall shift boot... it seems unlikely somebody would change all that on that kind of a truck if it was originally a first generation. It was the only standard cab pre third gen truck I could find in two yards so I scalped those brackets and a set of Explorer buckets, now it has EB BII buckets.
