94, once I swap axles, the current link bars will get cut up and reused for the new axles, unless you want to purchase them, I'll let you know what I'll need out of them...
Small updates...
With all the other projects going on, little progress is being made. In the last week or so I've gotten the temporary trans crossmember fabbed up (I'll need a different one when the doubler is finished), got the hydroboost finally plumbed, and got my air intake complete. I also managed to get my high steer arms drilled for my 1 ton steering, which I have yet to order...
Here is my hydroboost supply line I modded to work with my system...
Here is my trans crossmember...
I also git a little work done on the doubler that has been on the back burner for a while. I drilled the center out to 4" diameter, which matches the Dana 20's input case. Total measurement came to 4.020", so I've got about 10 thousandths clearance on each side, but the 4" x 0.250 wall tube I bought has went missing around the shop, and all the metal supply shops around here were closed on saturdays
so I can't finish the adapter plate til Monday. After that, I can get a measurement of my intermediate shaft length so i can finish assembly...
Here is one piece on the drill press...
Center drilled out...
Here are both plates(the reduction box on the left, the transfercase plate on the right) cut...
That's about as far as I got. What's left? Front brake pads and brake lines from calipers to mc, driveshafts, mount front tires onto rims and onto truck, relocate battery to bed, fill up the fluids, charge shocks and I should be ready for its maiden voyage...
SVT
