disciplerocks
July 2011 OTOTM Winner
- May 27, 2010
- Evansville, IN
Got a little work done. I'm using a 1350 planetary as a mock up. You can see the 6 gear 1354 set I will be swapping to.
Also figured out what I am going to do about shifters. I will use the stock linkage for the doubler case. And building my own linkage for the 1354e case. I will only need to be able to shift from 2hi to 4lo so it shouldn't be too bad. If I do need 4hi, then I can crawl under it and shift it manually.
