another area that's been causing me headaches is the upper firewall.
as you can see,it's past it's due date.
so i was sitting there looking at it and thinking things through,going over how best to attach an aluminum panel to the cowl,or whether i should just go with steel to replace it,when it hit me.
i want the body to be easilly removeable(remember that from about 200 pages ago?)and having to disconnect heater hoses and such doesn't count under 'easilly'.
the upper firewall would have to be a part of the chassis,and stay with it when the body shell was pulled...leaving the heater installed and unmolested.
so i made a template and sheared a chunk of aluminum.
did some drilling and bending...
and welded on end caps and a top flange.i still need to make the air inlet box for the heater that goes in the middle.i'm liking how this is going to work.
now,this brings up another item that has a few things that i would rather not disconnect...
the dashboard.this will be cut away from the cowl,i'll make a new one from aluminum and it will be a part of the chassis as well.
the only things left on the body shell to disconnect will be the taillights,interior light,and wipers.these can all be dealt with useing one electrical connector.
easy enough.
