- Jun 2, 2010
i get a blue spark at the coil and to the dizzy but not out of the dizzy the dizzu is new the plugs are good the wires are good and the coil is good new cap and rotor button and the battery is fully charged only thing i could think of bad spark is igniton timing.Does your battery have a full charge very important. How old are the plug wires if you don`t know change them so you do know. To check the coil and ignition module put A plug in the coil wire and set it on a good ground. Crank on it you should get a steady blue spark. To check just the coil turn the ignition on and take a jumper from coil neg to ground quick touches with the plug still in the coil wire you should get a crisp blue spark.
