Ford Ranger Dimensions
Do you need to know the measurements of a stock Ford Ranger:
1983-1992 Ford Ranger:
1983-1992 Ford Ranger Vehicle Dimensions
Regular cab short bed (6′)
Regular cab long bed (7′)
Extended cab
(First Super Cab was 1986)
Wheelbase, in. 107.9 113.9 125.0
Overall Length, in. 175.6 (1983-1988) 176.5 (1989-1992) 187.6 (1983-1988) 188.5 (1989-1992) 192.7 (1986-1988) 193.6 (1989-1992)
Overall Width, in. (excluding mirrors) 66.9 66.9 66.9
Overall Height, in. 64.3 64.3 64.3
Curb Weight 2526 2559
Cargo Box – Nominal Size 6 foot 7 foot 6 foot
— Inside Length At Floor 73.0 inches 85.0 inches 73 inches
— Tailgate Opening At Floor 54.2 inches 51.9 inches 54.2 Inches
— Max Width At Floor 54.3 inches 54.3 inches 54.3 inches
— Width Between Wheelhouses 40.4 inches 40.4 inches 40.4 inches
— Inside Height 16.6 inches 16.6 inches 16.6 inches
— Cargo Volume 37.5 cu. ft. 43.5 cu. ft. 37.5 cu. ft.
— Payload 1200 lbs 1200 lbs 1200 lbs
Head Room 39.2 inches 39.2 inches 39.2 inches
Leg Room 42.4 inches 42.4 inches 42.4 inches
Shoulder Room 55.6 inches 55.6 inches 55.6 inches
Hip Room 55.0 inches 55.0 inches 55.0 inches
1993-1997 Ford Ranger:
1993-1997 Ford Ranger Vehicle Dimensions
Extended cab
Wheelbase, in. 107.9 113.9 125.2
Overall Length, in. 184.3 196.3 198.2
Overall Width, in. (excluding mirrors) 69.4 69.4 69.4
Curb Weight, lbs.
Payload, lbs.
Payload Capacity, cu. ft. 1650 1650 1550
   — Length at floor, in. 71.8 84.6 71.8
   — Width at floor, in 46.4 46.4 46.4
  — Rear Opening Width At Floor, in. 54.4 54.4 54.4
   — Height, in. 16.4 16.4 16.4
Fuel Capacity, gals. 17.0
Front Head Room, in. 39.1 39.1 39.1
Front Hip Room, in. 52.8 52.8 52.8
Front Shoulder Room, in. 54.6 54.6 54.6
Max. Front Leg Room, in. 42.4 42.4 42.4
Rear Head Room, in. n/a n/a
Rear Shoulder, in. n/a n/a
Rear Hip Room n/a n/a
Max. Rear Leg Room, in. n/a n/a 41.2
Ground Clearance, Rear in. 6.7 6.7 6.7
Overhang – Front, in. 32.9 32.9 32.9
Overhang – Rear, in. (w/o bumper) 43.0 43.0 43.0
1998-2011 Ford Ranger:
1998-2011 Ford Ranger Vehicle Dimensions
Regular Cab Short Bed (6′)
Regular Cab Long Bed (7′)
Extended Cab (6′ Bed)
Wheelbase, in. 111.5 117.5 125.7 (125.9 4×4)
Overall Length, in. 189.4 201.4″ 203.6
Overall Height, in. 66.2 66.2 66.3 (67.7 4×4)
Curb Weight, lbs. 3010 3073 3179
Payload, lbs. 1180 1160 1260 (2.3L 4×2)
1340 (4.0L 4×2)
1380 (4.0L 4×4)
Cargo Volume, cu. ft. 37.4 43.7 37.4
   — Width at wheelhouse, in 40.5 40.5 40.5
   — Height, in. 16.5 16.5 16.5
Fuel Capacity, gals. 17.0 20.0 19.5
Front Head Room, in. 39.3 39.3 39.3
Front Hip Room, in. 52.7 52.7 52.7
Front Shoulder Room, in. 54.5 54.5 54.5
Rear Head Room, in. n/a n/a 33.2″
Rear Shoulder, in. n/a n/a 15.3 (14.1 4×4)
Rear Hip Room n/a n/a 19.4 (18.7 4×4)
Max. Rear Leg Room, in. n/a n/a 39.3 (39.1 4×4)
Ramp Breakover Angle, degrees 24.4°  24.5°  23.8°  (24.9°  4×4)
Angle of Approach, degrees 23.5°  24.3°  23.8°  (24.9°  4×4)
Angle of Departure, degrees 24.6°  21.2°  24.3°  (27.4°  4×4)
Minimum Ground Clearance, in. 7.9 8.0 8.0
Overhang – Front, in. 34.0 34.0 34.0
Overhang – Rear, in. 44.0 49.9 44.0 (43.8 4×4)
1998-2011 Ford Ranger Regular Cab Dimensions (more detailed):
Model Flareside (Box) (in.) Styleside SWB (in.) Styleside LWB (in.)
Code Description
A Wheelbase 4×2/4×4 111.5/111.6 111.6 117.5/117.6
B Overall Length 4×2/4×4 188.7 187.5/187.7 200.7/199.5
C Max. Width @ Rear Wheellip 4×2/4×4 69.4/70.3 69.4/70.3 69.4/70.3
D Leg Room @ Rear most Track Position 42.4 42.4 42.4
E Head Room 39.2 39.2 39.2
F Front Overhang 33.3 33.3 33.3
G Rear Overhang 4×2/4×4 43.9/43.8 42.6/43.8 49.9/48.6
H Shoulder Room 4×2/4×4 53.8 54.5/53.8 54.5/53.8
I Hip Room Front 52.7 52.7 52.7
J Frame Width @ Rear 32.8 32.8 32.8
K Rear Opening @ Floor 43.9 52.0 52.0
L Front Bumper to Rear of Cab 107.3 107.3 107.3
M Back of Cab to End of Box 77.2 77.1 89.1
N Width Between Wheelhouses 40.4 40.4 40.4
O Front Tread Width 58.6 58.6 58.6
P Max. Box Width @ Floor 43.9 52.0 52.0
Q Cab to Center of Rear Axle 37.5/37.6 37.6 43.5/43.6
R Inside Length of Box @ Floor 71.7 71.8 83.8
S Inside Box Height 16.7 16.5 16.5
T Rear Tread Width 57.3 57.3 57.3
Y Axle Clearance (Rear) (4×2) 6.7, (4×4) 7.4 (4×2) 6.7, (4×4) 7.4 (4×2) 6.7, (4×4) 7.4
1998-2011 Ford Ranger Super Cab Dimensions (more detailed):
Model Flareside
(stepside)
Styleside
Code Description (in.) (in.)
A Wheelbase 4×2/4×4 125.7/125.9 125.7/125.9
B Overall Length 4×2/4×4 202.9 202.9/201.7
C Max. Width @ Rear Wheellip 69.4/70.3 69.4/70.3
D Leg Room 42.2 (Front) 42.2 (Front)
40.3 (Rear) 40.3 (Rear)
E Head Room 39.2 (Front) 39.2 (Front)
35.6 (Rear) 35.6 (Rear)
G Rear Overhang 4×2/4×4 43.9/43.7 43.9/42.5
H Shoulder Room 53.8 (Front) 53.8 (Front)
15.3 (Rear) 15.3 (Rear)
I Hip Room 52.7 (Front) 52.7 (Front)
19.8 (Rear) 19.8 (Rear)
L Front Bumper to Rear of Cab 121.3 121.3
M Back of Cab to End of Box 77.4 77.3
Q Inside Box Height 16.7 16.5
S Cab to Center of Rr Axle 4×2/4×4 37.7/37.9 37.7/37.8
