Manual Transmission won't go into gear
CJDurden
Mazda
One day shifted fine no issues, the next it won't go into any gear with the engine on. With the engine off, it will go into all gears just fine. My truck is a 1997 Mazda B2300 with the 2.3L engine. It has the manual 5 speed from factory and the whole truck is original. I checked to see if there was anything leaking and there is not. Just looking to be pointed in the general direction to fix this thing. Any help is appreciated. Thanks.
trail B2
8
North Eastern Ca.
ford
4.0
It sounds more like a clutch problem than a tranny problem.Put it in gear with the motor off hold the clutch down and try to start it.Does it try to drive away with the clutch pedal all the way down if not does the clutch disengage like it used to.Check the clutch master cylinder[next to the brake master cylinder] to see if he has any fluid.If these confirm clutch problems start searching clutch repair options.
CJDurden
Mazda
Update
Ok so I went out there and checked the fluid. It was full. With the truck off I put it in gear and started it. It feels like it catches just a teeny bit but not enough to really count as "grabbing". When I started it like that I could shift all the gears with it running and pressing and releasing the clutch. After a few minutes of letting it sit in neutral, I would try it again and it wouldn't go into any gear again. What I am thinking is that it actually is a clutch problem maybe the throwout bearing or something. If I replace the clutch, I will be replacing everything I can get my hands on in there. Any opinions otherwise or maybe some different troubleshooting tips?
Earl43P
38
Farmington, Pa
Ford F250 4WD
3.0
I got a 93 really cheap with that symptom.
Its transmission was virtually dry/empty and the excess heat (I presume) made the slave quit working after about a mile. I put a replacement trans with a new slave in it.
Yours might just be a bad slave (or less commonly, the Master) but you should make sure the trans ATF is full, by removing the fill plug on the driver side.
Ak907Girl
TRS Banner 2012-2015
16
Anchorage, Alaska
4.2L/ 11,370Miles
My 93 doesn't like to shift sometimes either. I have to double pump a lot, I was told by my dad that it might be the clutch pack. Otherwise I don't know. Mine hates first gear, but after trying to shift into second then putting in first (before letting off the clutch) it'll go in. Let me know if you figure out what it is.
LIMA BEAN
140
ALASKA
2WD / 4WD
Make sure you dont have ice, carpet and floormat between the pedal and floor also. Have someone pump the clutch pedal and look at your lines to make sure they are not swelling up, it dont take much swell to loose it.
CJDurden
Mazda
So I let her sit for a day. I went out this morning and she went into all gears with the engine on and cold. I put it in neutral and let her get to normal temp and tried again. Went into all gears fine, no grinding or anything. So I decided to give it a test run. Drove it around the block getting into all gears just fine. Stopped and went in reverse for half a block and everything was fine. Took it onto the highway shifting gears fine. What is up with this thing. I couldn't GET her to NOT go into any gear. All the fluids are full, I haven't added anything or done anything to her yet. Any thoughts?
PS I checked the lines for swelling like Lima suggested and I couldn't see anything swell. I live in Texas so not a lot of ice here. There is no carpet underneath the pedal and nothing else to get in the way.
alwaysFlOoReD
Forum Staff Member
5,123
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
I had similar symptoms in my '85 b-II. I tried bleeding numerous ways and times, sometimes it seemed to get better?!?! I finally tracked it down to the flange on the master cylinder; it was broken on one side allowing the master to move, so incomplete movement INSIDE the master. I've also seen the floor boards ['87 ranger] have a crack that allowed master cylinder movement.
Food for thought.
Good luck,
Richard
remo1967
Tucson AZ
Mazda b3000
3.0
Same thing happened to my 2003 b3000 last week its a bad slave cylinder. So i replaced everything because i had it apart any ways
Tofflemire
I have a 1995 4.0 4X4 ford ranger with a manual transmission and it does the exact same thing with it not going back into gear after running for a little bit. It will go into gear if the truck is rolling but when I stop at a light I have to keep the clutch in because if I don't then it becomes difficult to get back into gear. DOES ANYONE KNOW HOW I WOULD CHECK TRANSMISSION FLUID LEVEL or have any other ideas? Not sure if its a related problem but I also notice when the gear problem is acting up it seems like the e brake pedal starts acting weird and also sounds like something is loose in the front end when I apply the brakes. Please if anyone has input let me know what you think. Thanks guys
Patrick
Mazda
Did this get solved? I had a 92 ranger with a 3.0 with a similar issue. I could shift while moving, but throwing it into gear at a stop was difficult and caused some grinding. Turned out to be a messed up pilot bearing inside the flywheel. It had just enough friction to turn the input shaft. Hope this helps. O know this is an old thread.
Sent from my Nexus 6P using Tapatalk
art1029
2
Raleigh NC
Engine Type
2.3 (4 Cylinder)
2WD / 4WD
2WD
Has anyone figured out a fix? I am having the same issue.
I have replaced the clutch master cylinder, clutch slave cylinder, new clutch, pressure plate, flywheel, new shifter bushings, replaced the transmission fluid, and bled the cutch....the truck still won’t go into gear. What am I missing!?!?
This was the original issue of why I started the project. The truck will start in neutral, but not go into gear while the engine is running. The truck won’t start when a gear is engaged.
Fnmarvin
Dallas
01'
Old thread or not i need answers My 01' 2.3 Ranger has always giving problems about idilingand going back into gear but last night I'm running down the highway about 70 mph in 5th gear when it went blam and blew out of gear luckily I was able to get it into 4th gear but nothing else I got it off the road safely but now I cant even get it into 4th. Thanks just telling someone who might can help is therapeutic right now. That's my only transportation. LMK
Dirtman
Former Middleweight Moss Fighting Champion
13,327
41N 75W
Engine Type
2.3 (4 Cylinder)
2WD / 4WD
2WD
It's up there.
Total Drop
It's down there.
Round.
I poop in the furnace.
Will it go into gear with the engine off? Is the clutch pedal still firm? Is there any noise when pressing the clutch (squeeks, chirps etc)? Have you checked the fluid in the master cylinder?
Fnmarvin
Dallas
01'
Sorry I had to run out and check your suggestions. Clutch is a little soft but fluids are good and shifts fine while off. But start it and it and it feels like its In 1st so i let out clutch and nothing. It grinds trying 2nd but wont go into gear. It wont grind any other gear or go into gear either. It's like I can shift into others with ease but no gear is there no grind nothing expect a grind on 2nd. I know I'm rambling and I hope you understand my explanation.
Staff online
Members online
Today's birthdays
Mudtruggy
May Truck of The Month
