When the customer removes the pump handle from its place on the side of the dispenser, this action activates a switch that starts the dispenser operation. (In some cases the switch is spring-loaded and activates automatically; in others, the customer must raise a small lever manually to begin the process.) At that point, the customer simply inserts the nozzle into the car's gas tank and pulls the lever. Stopping the flow of gas is just as simple -- the customer need only release the lever to cut off the stream of fuel.
But what if the tank fills unexpectedly to the brim and the gasoline threatens to overflow? As anyone who's ever operated a gas pump knows, the pump will switch off automatically. But how does the pump know when to stop pumping?
As the gas level in the tank rises, the distance between the dispenser nozzle and the fuel grows smaller. A small pipe called a venturi runs alongside the gas nozzle. When the end of the venturi pipe becomes submerged in the rising gas, it chokes off the air pressure that holds the nozzle handle open and shuts down the flow of gas. Unfortunately, this shutdown can sometimes happen before the tank is full as the rapidly flowing gas backs up on its way into the tank. This can cause the gas handle to spring open before pumping is complete, leaving the annoyed customer to squeeze the handle again and risk the possibility of overflow. Pausing briefly will allow the gas to continue into the tank and the pump nozzle to start pouring gas again.
The venturi has a leak and is letting it go too far.
