Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
- Aug 2, 2000
- Reaction score
- 8,731
- Location
- Nocona, Texas
- Make / Model
- Ford Ranger
- Engine Type
- 4.0 V6
- Engine Size
- 4.0 / 2.3 Ecoboost
- Automatic
- 2WD / 4WD
- 4WD
- Total Lift
- 6-inches
- Tire Size
- 33x12.50x15
Owner: LittleBigFoot
Vehicle: 2000 Ford Ranger
Specifications:
2000 Ford Ranger XLT, 3.0l flex (DEAD) 4r44e auto with electric BW1354
Front:
Full Width HP Dana 44
Molly shafts
4.30:1 gearing
Open diff
52" Chevy leaves with 8" shackles
3/4 ton ford van power steering box
1 ton TRE's
Home built high angle drive shaft (tom woods can eat my shaft)
Home brew shock hoops
Warn lock outs
Rear:
31 spline 9"
Molly shafts
4.30:1 gearing
Open diff
63" chevy 1/2 ton leaves
Belltech shackles
2" block
5/8 u-bolts
Cantilever shock system
Home made drive shaft with 1350 yokes
Tone Ring is a BMX bike gear tacked to the pinion yoke with a bracket for the vss.
General:
Around 8ish inches of lift
35x15r15 super swamper LTBs on gnarly offset stock 79 Bronco Rims
82" track width (out side of tire to outside of tire)
112" wheel base
Measured at 22" of wheel travel front and rear
Tube stinger bumper made of .120" wall, 1.75" O.D. HREW with front receiver hitch
Home brew rock sliders made of .120 wall 2" O.D. HREW
33 gallon fuel tank from a 84 bronco massaged between the frame rails
Custom home brew "flat bed" made of 1.75" O.D. .120" wall square stock and diamond plate
A few spare tire carriers
Cobra CB with 48" antenna
Amo box center concile
Rubber undercoated floor with drain plugs
Fried the rings in my 3.0. Pulling the 3.0 currently, and am building a supercharged 408 or 427w w/ a C6 trans. Still dealing with transfercase options. Trying to rig up passenger drop to run a Chevy Dana60 (cost)
Looking at a np203 range box bolted up to a pass drop NP205.
IT'S NEVER OVER.
For more details and photos, click HERE.
