Writeup: 4.0 swap 94 Ex to 89 B2
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS 25th Anniversary
8,796
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Thanks! Added to online magazine.
disciplerocks
July 2011 OTOTM Winner
53
Evansville, IN
Cool. Thanks Jim.
BabyBronco89
GR Michigan
95' 4.0 OHV
Thanks for the link to ur swap
this is the write up Ive been looking for!
you went into a lot more detail about the wiring aspect of things
which still leaves me with quite a few questions.
do i use most of my 2.9l wireing harness (computer connection distribution block)? and plug in my 4.0l man trans computer into that and splice 4.0 sensors into my 2.9l harness?
or do i Try salvaging as much of the 91 auto 4.0 ex harness that i can?
some parts that scared me were i have a electric shift transfer case
n everything in my bronco II is power
electrical stuff just scares me, when u start adding colors and stripes i freeze up >.<
I do plan on upgradeing my trans to a m5od along with the 4.0l flywheel and clutch basket. at a later date as funds are very low right now
i have a newer 2.9 clutch about a yr old along with new slave cylinder throwout bearing and master clutch clyinder in the last two months.
i was under the impression that this is possible as both the 2.9 and 4.0 flywheel use the same number of teeth
and that the 2.9 and 4.0 use basically the same clutch internals
I've been reading up on this swap for about a year and Im putting together the final pieces now
a lil history
three months ago i went through entire engine after cracking a head and blowing gasket. (new oil pump,good junkyard heads(new valve seals and valves lapped and cleaned up) water pump, gaskets all the way around, only thing i didn't do was bottom end bearings.
now im haveing more head/gasket/overheating problems so im decideing to scrap this never ending battle with my 2.9 n go for a little more dependable 4.0
this is my only vehicle and daily driver. and the most im trying to have it off the road is a week
disciplerocks
53
Evansville, IN
You need the 4.0 distribution box and ecu plug. You should cut between the distribution box and passenger headlight.
1989ranger4.0
hey man im new her but i got a 1989 ford ranger with 2.9 to a 1992 ford explorer 4.0, any ways i took both wiring harness of the exlorer. and put them on ranger. i then went to crank over and didnt i then to the old 2.9 wiring harness tht plugs in to driver side of cab and now everthing works except no fire or fuel but there is a wire that is on injector rail and hooks to them and coil pack but the only problem is i dont have place to hook it can you please help
disciplerocks
53
Evansville, IN
Kinda hard to understand your post.
1989ranger4.0
wellthe main problem right now is that there is a plug that connects with injectors and coil and i dont have anywhere to plug in
disciplerocks
53
Evansville, IN
There is a sensor that sits under the intake. Maybe thats it? Shoot a pic and I'll see if I can find it.
1989ranger4.0
thisis it i went to junk yard it looked like it went to frame rail might go to fuel tank
disciplerocks
53
Evansville, IN
Passenger side O2 sensor
1989ranger4.0
do you got anysuggestions on what to try to get fire and fuel
disciplerocks
53
Evansville, IN
Bypass the clutch pedal switch and the neutral safety switch.
1989ranger4.0
just currious why would tht have anything to do with it not getting fuel and how would i go about this
disciplerocks
53
Evansville, IN
Just my suggestion. The NSS was what was keeping me from starting mine.
1989ranger4.0
and how would i bypass tht
