winter/snow rated tires
neondave
Loveland,Colorado
Ranger XL 2wd
been looking for winter/snow tires for the rear of my 1994 Ranger. It has 14" wheels and have had no luck. A store called Les Swab shows a 225-70-14 wintercat sst but the local dealer cant say if or when that tire might be available, ant ideas ?
When ya have 14" wheels , your out of luck. Thanks,Dave ( Colorado )
1990RangerinSK
1,312
Saskatchewan, Canada
Two things:
First, I would recommend buying FOUR. You'll find that, while two winter tires on the rear axle would give you better traction for acceleration, four winter tires (two on each axle) will also give you better traction for steering and braking, given that most of your braking is done on the front axle.
Second, not all tire brands are available in every size. I never bought them, but in 2016, I was able to source a set of Firestone Winterforce tires for my Ranger on 14's.
Which ever tire you get, I would suggest getting them studded. I had Firestone Winterforce tires on my Fit that were studded. They were loud, but I REALLY liked the traction!
97RangerXLT
TRS 25th Anniversary
4,032
Fishers, IN
2"
31"
This.
as for studded, most states in the US do not allow unless you are a postal carrier. Check with your state. if they are allowed, yeah, get the grippies :)
and for a little bit of cost (maybe 100 bucks or less) you can get a set of steel junkyard 15 inch Ranger rims and open up your possibilities much wider.
AJ
neondave
Loveland,Colorado
Ranger XL 2wd
yes, my old snow tires are winterforce , but a local tire shop said that size is discontinude :(
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Depending on what the truck is used for, chains are another option. I love my nasty v bar chains, I can get through crap with them in my 2wd ranger that will stop most jeeps. But they are a massive pain in the ass taking on and off and will rattle your teeth out if you go above 30mph. I'd do what @97RangerXLT suggested and just go buy a really cheap set of junkyard steel 15" rims. Its always better to have 2 sets of rims for your winter and summer tires anyway.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Remove tire from rim.
Shoot roofing nails everywhere
Refill with two cans fix a flat
14" studded tires.
8,374
Snow tires use a compound that stays pliable under 40degF
Regular, or 3 season, tire compounds start to get hard under 40deg, and have a real hard time gripping under 30deg
But regular tires are fine up to 100deg
Snow tires will start to wear heavily above 60deg, wears off the softer tread faster, so you DO NOT want to run snow tires in warmer weather
So I would do as 97RangerXLT suggested, get 4 steel plain jane rims at wrecking yard and then get snow tires for those
But find a deal on the snow tires FIRST so you know what size rims to get
And you can sometimes find used snow tires at the wrecking yards but the staff there usually take the best ones, lol
1990RangerinSK
1,312
Jackpot! Move up to 15's, as mentioned above. The tire size you want is 205/70/15. TireRack has Firestone Winterforce, and they're studdable. Link: https://www.tirerack.com/tires/TireSearchResults.jsp?zip-code=12345&width=205/&ratio=70&diameter=15&rearWidth=205/&rearRatio=70&rearDiameter=15&performance=W&cameFrom=WinterSection
Now all you need is a set of rims, and TireRack has those, too. Just get cheap steal rims, and they might even ship them to you mounted. Or, as mentioned above, you can get rims from a junk yard. Most tire shops will take your tires and rims, and mount them for you.
