Will a 2000 mountaineer 8.8 fit my 97 ranger
Shadowrider6661
D RANGED
ASE Certified Tech
129
Off grid Northern Arizona.
Stock
4"
N/A
33 x 12.50 x 15
Drive it, Break it, Fix it, REPEAT !
Question answered. TRS is a site to be proud of, full of Great People !
I was recently given a 2000 Mountaineer 4x4. It has a D4 8.8" LSD rear w/disc brakes, will it fit a 97 ranger ? My thanks and appreciation to all for answering my question.
scotts90ranger
4,554
Dayton Oregon
2.3 Turbo
It is the same as swapping in an Explorer axle, you have to rework the parking brake cable a bit, do some brake line work, weld on new spring perches and shock mounts but that's about it...
tinman_72
139
North Georgia
2.5 (4 Cylinder)
2.5
Factory
None
255/60R15
RoHS compliant
You have to move the spring perches and I think the shock mounts as well so a little welding is involved.
Ranger850
Doesn't get Sarcasm . . .
4,717
Tallahassee Florida
Stock 2"
Stock
What color interior in the Mounty? I'm looking for green interior parts
Shadowrider6661
D RANGED
ASE Certified Tech
129
Stock
4"
N/A
33 x 12.50 x 15
It has a green exterior, I would have to look inside and check. I will let you know when I get a chance. Also, thank you for answering my qustion.
Shadowrider6661
D RANGED
ASE Certified Tech
129
Stock
4"
N/A
33 x 12.50 x 15
Thank You !
Shadowrider6661
D RANGED
ASE Certified Tech
129
Stock
4"
N/A
33 x 12.50 x 15
Thank you for your answer.
Shadowrider6661
D RANGED
ASE Certified Tech
129
Stock
4"
N/A
33 x 12.50 x 15
Shadowrider6661
D RANGED
ASE Certified Tech
129
Stock
4"
N/A
33 x 12.50 x 15
