How did I know that magazines were going to be the first comment I received. My magazines:
1 - 30rd Thermold
1 - C Products Aluminum 30 rd
2 - C Products SS 10 rd
3 - El cheapo Sportsman's Guide steel 10-20 rd (I've all but thrown these out)
They all do the exact same thing in my rifle, regardless of how they are loaded. All but the 3 cheapos work fine in dad's AR-15, and they work better in his than they do in mine. I've also tried a couple of dad's mags (can't recall brands) with the same results.
1) I hear you about breaking it in but I've already shot a couple hundred rounds through it, and the amount that it happens is unacceptable even for a new rifle. Comparing it to dad's again but his never did this straight out of the box.
2) I've tried about 4 different brands of ammo with the same results. Dad's shot my worst ammo and it worked fine.
3-4) I've checked these out once, but I'll certainly look again
5-6) I partially suspect this. After purchasing I had the original sight style gas block replaced with a low profile version to use with a scope (flattop upper). I had this problem before the block was replaced, but that doesn't mean it was lined up right from the factory. It is the 16" barrell, just not colt.
7) I also suspect this, but not sure how to check that it is the right one. As mentioned above it's 16" barrel and had fixed stock.
8) Ordered a JARD adjustable single stage last Friday. So if that's an issue not, it shouldn't be for long.
9) Will check it as soon as I have a chance.
10) Seems to be good there. I'll double check on the magazine, but I'm 99% certain it's good.
First thing we need to do is determine if it is short stroking or if it is a failure to feed.
Failure to feed is a magazine issue.
Short stroking is a gas issue.
Once we determine what the issue is we can start working toward the solution.
Short stroking (Failure to cycle)
Short stroking on an AR rifle is when the bolt carrier group does not cycle far enough to the rear to be able to strip a round from the magazine and chamber the next round. After firing a round, you will notice that the bolt is closed on an empty chamber, thereby forcing you to manually cycle the rifle to feed the next round. This occurs when there is an issue with the gas system.
To see if you have a short stroking problem and not a “Failure to Feed” problem, please perform this test first (assuming your bolt catch and magazine is functioning properly). Insert one round into a magazine that you know to be performing well. Insert the magazine into the magazine well, pull the charging handle to the rear, then release the charging to load the round into the chamber. Safely discharge that round. After the round has been fired the bolt should automatically be locked to the rear by the bolt catch and the empty magazine. If the bolt is closed on the empty chamber, then it did not travel far enough to the rear to be held by the bolt catch, and your rifle has short stroked.
Short stroking is a symptom of a problem with the gas system in the rifle. There are 7 parts of the AR gas system. In the upper receiver group, you have the barrel (gas port), front sight base, and gas tube. In the bolt carrier group you have the gas key, the carrier, the bolt, and the gas rings.
Assuming the rifle was running correctly previously (in the exact configuration it is currently) The following is a basic trouble-shooting checklist.
1) Ammo issue ? Commercial ammo does not run as hot as Milspec ammo, and some lots of commercial ammo may not be strong enough to cycle the weapon. Try a completely different type of ammo. If the weapon works correctly then you may have some bad ammo. This is becoming a more common problem with some of the low cost imported ammo, especially with milspec sized gas ports.
2) Lube and clean the rifle. Pull out your GI manual and properly clean the weapon. As a note, a little bit of dirt and carbon should not stop the proper cycling of your rifle.
3) Check the carrier (gas) key. If the carrier key is loose, the gas system will not hold enough pressure to fully cycle the weapon. Try a different carrier that you know to be working in another properly functioning weapon. If the weapon runs well with the other carrier, you may have an issue with your carrier key. The carrier key bolts should not be loose. It should be staked from the factory. Check to make sure the bolts securing the key did not rotate past the staking. The bolts should be torqued to 35-40 in/lbs.
4) Check the gas rings. (or just go ahead and change them – they are very inexpensive) Mythbuster: The gaps in the gas rings do not need to be staggered. I know we were all taught otherwise in recruit training, and yes I know it says they must be staggered in the GI manual. But this is a myth. As a note; it will not hurt the system to stagger the gaps in the rings, but if this single change makes the difference – you need new gas rings ASAP. Inspect the rings, make sure there are 3 of them, and that they are installed properly. Disassemble the carrier group, insert the bolt into the carrier, and hold the carrier vertically in the air. The bolt should not fall out of the carrier.
5) Change the gas tube.
Failure to Feed
A failure to feed initially looks similar to a short stroking problem. A round is fired, a spent case is extracted and ejected, but the bolt is closed on an empty chamber. The difference with a failure to feed is that the bolt did travel far enough to the rear to chamber a round. But it did not, and it is now closed on an empty chamber. Generally speaking, this is most often caused by a defective magazine (specifically a problem with the feed lips). You might also notice 2 dents in the casing that is still loaded in the magazine from bolt over-ride. The solution is to replace the magazine. USGI magazines are class 9 expendable and should be replaced when defective.
http://www.ar15armory.com/forums/AR15-Troubleshooting-Tec-t5332.html
Have you tried shooting your upper on your dads lower?
Lol no need to get so technical. He understood my point and meaning.
Just because he understood it doesn't make it right. It's just one of those things that drive me ****ing nuts. Like when people put u instead of typing you, or ne instead of any. Or when people use the wrong there/their/they're.
I understand.
I use rifles as firearms as an investment. Cheaper to get a rifle then an ounce of gold. I get a discount cause im the leprechaun and gold is still high.
Your built (best parts available) vs. Something that says COLT on every part. Ten years down the road value wise the built rig is damn near worthless.
I bought the .22 as a shooter because it was a steal at $350. And cheap to run 1k rounds through it.
If I was looking for a toy. I would definitely build my own though and it would be a 7.62.
Not true at all. Sure it may not be as easy to sell. You need a build sheet and a buyer who knows AR's. Ten years down the road your Colt will be worth a grand, same as it is today. Ten years down the road my built rig will be worth 2K, same as it is today.
Ever since the Fed assault weapons ban expired in 2004 there has been a huge influx of AR manufacturers to the market. And that is not likely to change any time soon.
Here is a short list of manufacturers.
1 Adams Arms
2 ADCOR Defence
3 Addax
4 ADEQ Firearms Company
5 Advanced Defense Sysems (ADS)
6 Aeroprecision
7 AGP Arms
8 Alberta Tactical Rifle Supply
9 Alexander Arms
10 All Weapons One
11 Allstar Tactical LLC
12 Alpha Shooting Sports
13 Ambush Firearms
14 Ameetech*
15 American Precision Arms
16 American Spirit Arms
17 American Tacitcal Imports (ATI)
18 American Weapon Systems
19 Anderson Manufacturing
20 Anvil Arms*
21 AR 15 Plus
22 AR Permformance
23 AR15 Depot
24 AR15.com Armament Rifle
25 AR57 Center
26 Ardel Engineering (AE)
27 Ares Arms LLC.
28 Ares Defense
29 Arizona Armory (AZ)
30 Armalite
31 Armitage International LTD
32 ARMS LLC
33 Arm's Tech LTD
34 Astra Arms
35 ATT Tactical
36 AXTS Weapons
37 Balimoy
38 Barnes Precision
39 Barret Firearms Manufacturing
40 Bartlett Enterprises
41 Battle Born Rifles
42 Battle Rifle Company
43 Bazooka Brothers Manufacturing
44 Black Dawn
45 Black Diamond SOCOM Mfg.
46 Black Gold cusom Arms
47 Black Heart International
48 Black Hole Weaponry
49 Black Rain
50 Black Scorpion Firearms
51 Black Weapons Armory
52 Blackthorne
53 BMG Inc
54 Bohica Arms
55 Bradley Arms
56 Branch Custom Weaponry
57 Bravo Company Manufacturing (BCM)
58 Bushmaster Firearms International
59 C3 Defense
60 Cavalry Arms*
61 Centurion Arms
62 Centurion Tactical
63 Century
64 Century Arms
65 Charles Daly
66 Chattahoochee Gun Works LLC
67 Chengdu Hongguag Machinery Manufacturing Co Ltd
68 Chiappa Firearms
69 Christensen Arms
70 Christian Armory Works (CAW)
71 CIV Tactical
72 CMMG
73 CMS*
74 Cobra Tactical
75 Colt's
76 Compass Lake Engineering (CLE)
77 Conquest Arms
78 Controlled Chaos Arms
79 Core15
80 Crusader Weaponry
81 D.S. Arms
82 Dalphon Firearms*
83 Daniel Defense
84 Dedicated Technology
85 Delaware Machinery
86 Delta Arms Company
87 Del-Ton
88 Denny's Guns
89 Detroit Gun Works
90 Diemaco*
91 Dlask Arms
92 Double Diamond Law Enforcement Supply
93 Double Star
94 DPMS / Panther Arms
95 Dreadnaught Industries
96 Duty Precision Machinery Shops (DPM Shops)
97 Eagle Arms
98 East Coast Gun Sales"
99 Echigoya
100 Edward Arms
101 Elite Arms
102 Essential Arms
103 Fabrique Nationale
104 Firebird Precision
105 Frankford Arsenal
106 Franklin Armory
107 Frozen North Firearms*
108 Fulton Armory
109 GA Precision (GAP)
110 Galati International
111 GAR Arms
112 Global Tactical
113 GM Corp.*
114 Good Time Outdoors Inc
115 Grenadier Precision *
116 Group Industries*
117 GT Vertical Concepts (GTVC)
118 Gun Smoke Enterprises
119 H&H Enterprises
120 Harrington and Richarson (H&R)*
121 Hatcher Gun Company
122 Head Down Products
123 Hecklor and Koch
124 Henderson Defense
125 Hera Arms
126 Hesse
127 High Mountain Hunting Supply
128 High Standard Manufacturing Company
129 Hogan guns
130 Holland Gun Works
131 Houlding Precision
132 Huldra Arms
133 Integrity Arms and Survival
134 Iron Ridge Arms
135 JARD Inc.
136 JD Machine
137 JP Enterprises
138 JSE Surplus
139 Kaiser Defense
140 Kiss Tactical
141 Knights Armament Co. (KAC)
142 Kurt's Kustom Firearms (KKF)
143 L&G weaponry
144 Lancer Systems
145 Land Warfare Research Company (LWRC)
146 Lantac, UK
147 LAR Grizzly
148 LaRue
149 Lauer Custom Weaponry (LCW)
150 LBR Arms
151 Legion Firearms
152 Les Bauer
153 Lewis Machine and Tool (LMT)
154 Liberty Arms
155 Liberty Tactical
156 Loki
157 Lone Wolf Distributing
158 M Weapons
159 Mack Gwinn Industries (?) (MGI)
160 Magpul
161 Mattel Corp.*
162 McKay Enterprises LLC.
163 Mean Metal Inc
164 Medesha Fireamrs
165 Mega Arms
166 Model 1 Sales
167 Mohawk Armory
168 Molot
169 Mossberg
170 National Ordinance Company
171 New Evolution Military Ordinance (NEMO)
172 New Frontier Armory
173 Next Generation Arms
174 Nodak
175 Nordic Components
176 Norinco
177 North East Arms
178 Noveske
179 Oberland Arms
180 Olympic Arms
181 Palmetto State Armory
182 Palmetto State Defense
183 Para - USA
184 Patriot Defense Arms
185 Patriot Ordinance (POF)
186 Plum Crazy
187 Precision Firearms
188 Precision Guncraft
189 Predator Custom Shop
190 Predator Tactical
191 PRI Uppers
192 Primary Weapons Systems (PWS)
193 ProArms
194 PWA*
195 Quality Arms
196 Quentin Defence
197 R Guns
198 Rainer Arms
199 Ratworx
200 RCM Gun Parts
201 Red Jacket Firearms
202 Red X Arms
203 Remington
204 RGM inc
205 Rifle Dynamics
206 RifleGear
207 RND
208 Rock Island Arsenal
209 Rock River Arms
210 Rocky Mountain Arms
211 Roggio Arsenal
212 Ruger
213 S I Defense
214 Saber Tactical
215 Sabre Defence*
216 Scorpion Tactical
217 Seekins Precision
218 Senda Corp*
219 Sendra
220 SGW*
221 Shadow Ops Weaponry
222 Sharps Rifle Company/Sharps rifle
223 Sig Arms
224 Sionics
225 Smith & Wesson
226 SNS Industries*
227 SOCOM Mfg.
228 Sog Arms
229 Sonju Defense
230 Southern Gun Co.
231 Specialized Dynamics
232 Specialized Tacitcal Systems
233 Spike's Tactical
234 Stag Arms
235 State of the Art Arms (SOTA)
236 Sterling Arsenal
237 Stinger Arms
238 Sun Devil
239 Superior Arms
240 Suplus Ammo and Arms
241 Tactial Weapons Solutions
242 Tactical Ammunition
243 Tactical Arms Manufacturing
244 Tactical Innovations
245 Tactical Machining
246 Tactics LLC*
247 Templar Custom
248 Templar Tactical Arms
249 Teppo Jutsu LLC.
250 Thompson Machine
251 Thor Glocal Defense
252 Timberwolf Tactical
253 Titan Ordinance
254 TKS Engineering
255 TNW Firearms
256 Tommy15
257 Top Notch Tacitcal (TNT)
258 Triplett Firearms
259 Tromix
260 U T Arms
261 Umbrella Corporation Weapons Research Group
262 US Fireams Academy
263 USA Tactical Firearms
264 Valkyrie Arms
265 Vidalia Police Supply
266 Vltor
267 Vulcan Armament
268 WFC Proshop
269 White Oaks Armament
270 Wilson Combat
271 Windham Weaponry
272 Xtreme Machinig
273 Yankee Hill Machine (YHM)
274 Z M Weapons
275 Zel Custom Manufacturing
276 Zombie Defense
My point is the AR 15 isn't going away any time soon, and high end parts demand a premium price now and they are going to demand a premium price 10 or 20 years down the road too.
-Jester
