Which Ranger should I buy?
Ranger_XL
45
Wind Gap, PA
Ranger XL
I'm sorry, did you say "manual transmission"?
We're friends now.
Every vehicle I have ever owned (2000 Pontiac Trans Am WS6, 1997 GMC Sonoma SLS, 2016 Chevrolet Spark LS, 2003 Ford F-250 Super Duty XL, 1994 Ford Ranger XL, 1996 Ford Ranger XL, and 2000 Ford F-250 Super Duty XL) has been equipped with a manual transmission.
ExploreNW
131
Mead, WA
I'd say get the '96 2.3. Simple reason: OBD-II is your best friend if you're not a regular wrencher. Onboard diagnostics accessible through cheap easy handheld devices will tell you exactly what you're going to be swearing at for the next several hours. At least as long as the PCM itself isn't the problem. The OBD-1 on the '95-earlier (California-Only '95s got OBD-II) trucks is a bit clunkier and requisite diagnostic hardware is tougher to come by.
That said, perhaps it is not a question of which Ranger... but instead, how many Rangers?
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
I'd tend to.disagree. Obd1 vehicles are much easier to work with via diagnostics due to simplicity alone. Other advantage is tuning if you're so inclined.
stsalvage
20
moreno Valley
i have 2 ranger
Ranger XLT exte
4.0 & 2.3
Or spend a day doing a heater core swap.... Not every vehicle needs a heater core swap if they are taken care of.... That's a lot of personal preferences.... This will be a buyer preference for sure.... Sounds like it will be a daily driver so the 4 cyl would be the better choice as the 3.0's get terrible gas miles unless you have the 5 speed and even then its worse than most v8's lol. Although being a 4 cyl leaves you wanting more power.... Yeah its a fun truck until you are trying to merge onto 80mph freeways with dumb drivers that aren't getting over and you got the pedal to the floor struggling to hit 70..... At least the 3.0 has some get up and go. Don't let the haters tell you it's slow, most of the time it's just a stretched throttle cable which means yes it will be slow when full throttle gas pedal is only opening the throttle body half way....
I got a question when was the last time you drove a 100 HP 1984--1999 2.3 with 8 spark plugs I will day if your like getting your jolly's off praying if you can climb a steep hill without going more then 5 miles per hour You can mcloveen all you want on the 2.3 to me the 4.0 Is the only choice to have in a ranger with a 5 speed Its more dependable Plus you ever push a auto and get her started with a bad starter or a bad battery NOPE
stsalvage
20
moreno Valley
i have 2 ranger
Ranger XLT exte
4.0 & 2.3
ON the true Rangers that have survived. 1983--1987 will never make it in a Smog State So the second-gen Rangers from 1990--1994 that had the 4.0 and the none 2.9 engine and the none Air bag trucks.
Most of the trucks I've had any goodness from are from the 1989--94 Cus in 195 the EGR valve came back so did a lot of BS If you want a truck you can work on and have around for a long time I like the 1990--1994 you know the dash is different in the 1994 from the 1995 And that is where your heater comes in. The guy that called me out on the heater core problem.
Question ?
What is the one thing in all cars and trucks that is not grounded and it should be. And why should it be grounded!!!!!!!!!!!!!!!!!!!!!!
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Question ?
Just throwing this out there...
snoranger
Professional money waster
ASE Certified Tech
13,677
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Question ?
The driver, because he was bad.
racsan
4,481
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
just a hour ago on the way home, with 4.10’s a 2.3 aint bad. no it aint no 4-litre but it doesnt do too bad. the roads havent been salty this week so Ive been enjoying my ranger and letting the hhr rest. I do miss the better heater and cruise control though.
snoranger
ASE Certified Tech
13,677
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
