where to run the co ax cable?
88ranger89camaro
Firefighter
Squaw Valley, CA
2.3
so be short about it
signal is mesured in dB, when you got lose its decreasing the dB gain or "Attenuation" is the science term for it
so basily its like my other referance of putting H.P. to the ground, its like losing H.P. through the driveline
86MUDRCJ
8
Sheridan, CA
Oh gotcha thanks a bunch man!
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Yep, the lower the signal loss, the more that actually reaches your antenna (the reverse is true on received signals as well, a better cable can let you hear people better too).
86MUDRCJ
8
Sheridan, CA
Thanks guys that helps alot. Ill be sure to post up when I get it all in.!
