please for the love of your CB dont go to rat shack, find a truck stop or CB shop that has the rg8 and not mini 8 (rg8x) ....... i know all my rat shack has is crap for coax
I hope you also know about setting your SWR so you dont fry your radio, if not ask, ill post up what you need to know
edit: mini 8 will be ok IF you are not running a linear (amp)
Using RG8 for CB on a short run of cable on a typical pickup truck is a complete waste of effort forcing that stuff around.
It would barely be worth it to run big cable like that for UHF frequency
(Loss of coax increase with frequency)
RG58CU cable is good enough but if you have the skills and patience
RG8X also known as "Mini-8" is about half the loss of standard RG58A
coax.
And before you say :
"running an amp you need the larger cable"
my counter arguements are:
A)Amps are ILLEGAL
B)RARELY produce the quoted power
C)generally do little more than increase the noise on the band,
yeah you can be heard but don't improve your ability to hear.
If you go with RG58U avoid the RG58
AU
"A" has a solid center conductor, RG58
CU
has a stranded center conductor which allows it to be more flexible
and less prone to breaking as it's flexed.
Does Full size RG8 cable have lower loss at CB frequencies than RG58?
Yes it has about 10% less Loss.
But as the lose on a typical 10foot run of cable is "Trivial" at 27MHz...
Even on my amateur radio running at 146MHz & 445MHz and running
ten times the power... it's still not worth running RG8 Coax in my truck.
IF you wanna be taken seriously about "Big cable" on BASE radio setups you
want to be talking about Belden 9913 cable or Andrews HardLine
AD
