When to rebuild?
chewy012
Colorado Springs, CO
4.0 OHV
Not a ranger, but I've a vehicle that's had some good blow by for awhile, finally bought a compression tester.
115, 100, 100, 125 psi on the cylinders.
Doesn't knock or burn oil, I don't think it's immediately necessary, buy it is starting to struggle starting.
It's a 2.4L Honda i-VTEC with 143k.
Is it due for a rebuild? Or does it have maybe a few more years?
Thanks!
Sent from my XT1254 using Tapatalk
Roughly 10% loss from high to low cylinder is the acceptable limit. You have 25%. I'd say time to rebuild happened about 20-50K miles ago.
chewy012
4.0 OHV
^well damn haha. Yeah I've heard 10-15%.
97RangerXLT
TRS 25th Anniversary
3,966
Fishers, IN
2"
31"
that is pretty low mileage for needing a rebuild... especially on a Honda. the hills around you must be wicked there in Colorado :)
AJ
8,372
What year is it?
Your compression numbers are very low over all, so I would suspect a testing issue first.
It should have 10 to 11:1 compression ratio, putting it at 180-198psi expected
And variable valve timing(VTEC)
Your engine should be in one of these lists: https://en.wikipedia.org/wiki/Honda_K_engine
chewy012
4.0 OHV
It's an '03 CR-V, 9.6:1. Also I'm at 6000 ft, atm here is 11.8 psia...
Also that was a dry test. I may have not given it enough turns with the key
chewy012
4.0 OHV
AJ
That's what I thought haha it was city driven in Seattle area for the first 2/3 of it's life.
8,372
Dry is fine and cold engine is as well
You loose about 3psi of compression per 1,000ft elevation
I use 18 as compression multiplier, 15 for sea level air pressure and 3 for mechanical compression
18 x 9.6 = 172.8
172.8 - 18(6,000ft) = 154.8psi expected, dry and cold testing
Wet test after dry test would tell you if rings are the issue
Andy D
10
Marshfield MA
The Rat
4.0 OHV
to prevent Found On the Road Dead, Fix Or Repair Daily
do the valves need adjusting?
Andy D
10
Marshfield MA
The Rat
4.0 OHV
Not sure, I don't hear any rattle or ticking.
Tight valves are quiet, too quiet. DIL's '99 DOHC CRV burnt a valve around 100k. Valves tightened due to valve seat recession
chewy012
4.0 OHV
Hmmm, good tip, thanks, I'll have to take a look at that.
