what solid axle would be best for a 99 ranger
swampdaddy14
ellensburg WA
v6 4.0
i've got plenty to pick from for my SAS but i don't know which one would be easiest and the strongest to swap in. I have been thinking a dana 35?
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
The Dana35 never came as a solid front axle.
Some people use Dana 30s from a Jeep Cherokee XJ (maybe that's what you meant?). I think it's a bit too light-duty of an axle if your truck is a Supercab, however it's likely to work better for you if you have a regular cab truck.
For a Supercab truck I suggest a D44 of some sort. Ones from a '80s Jeep Wagoneer are popular, as are ones from F-150s (either left full-width, or narrowed down 6").
Search around some, this has been covered a lot here already. :icon_thumby:
Moved to non-RBV axles
Hagan
08/2013 OTOTM Winner
11
Salem, OR
2.3
The best axle depends on what you are using it for.
swampdaddy14
ellensburg WA
v6 4.0
it would be mostly on road but would be taken off road alot too
swampdaddy14
ellensburg WA
v6 4.0
yeah i'm a dumbass i meant Dana 30 ha ha. can you find a narrow dana 44 at a junkyard or is that something you do yourself?
Hagan
11
Salem, OR
2.3
You narrow a Dana 44 yourself. Unless its one from a Jeep like he said. There is an article in the tech library.
PlumCrazy
2014 Truck of The Year
179
Millersport, OH
Solid Axle Swap 4x4
EB Bronco D44. They are low pinion, but they are perfect width for an RBV. I have had 0 trouble with mine.
-PlumCrazy
swampdaddy14
ellensburg WA
v6 4.0
would it work if i put front and rear non shortened dana 44s? I think it would look badass
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
People do it all the time. Do a quick search.
-PlumCrazy
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
Pointless to put a D44 in the rear when you can find stupid cheap disc 8.8's anywhere that are easy to build.
swampdaddy14
ellensburg WA
v6 4.0
so heres what ive decided to do
Talked to my buddy who owns a junkyard and he is setting me up with jeep wagoneer front rear axles and the suspension (coilover)
using the ranger steering box (not sure if that will work)
also im not sure about the lug pattern how hard is that to swap out?
will this work?
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
will this work?
98+ Rangers dont have a steering box......
Wagoneers are leaf sprung....
swampdaddy14
ellensburg WA
v6 4.0
the one i found did or at least thats what he told me. so how should i set up the steering?
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
Look for builds where guys SAS newer trucks. Toyota boxes and earlier Ford trucks are popular because they mount to a flat surface.
-PlumCrazy
