What size fan in a 92 Ranger 4.0l
sumncguy
18
Hillsborough NC
at least 6"
32x11.5x15
The 92 I bought a while back had a shotty install of the electric fan.
It is no longer turning on. I want to rip out whats there and reinstall a new one.
Can anyone tell me what size fan is in there. I tried to measure .. but definitely not accurate.
Wanting to by the Champion Cooling fan. Comes with installation kit. Fans shown are 10, 12, 14 an 16 inch.
Thanks in advance for any help you can provide.
Regards
Sum
franklin2
1,768
Virginia
I had one of their 16 inch fans on my ranger and it just kept up with the cooling. I would not go any smaller. I used the "wire ties" through the fins kit that comes with the fan and never had any problems with that mounting method.
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Biggest one that will fit. Also mind the CFMS. Not all of the same size have the same CFMs. Get one that has a lot.
sumncguy
18
Hillsborough NC
at least 6"
32x11.5x15
Ok thanks fellas. Anything has to be better than nothing.
I didn't want to tear it apart until the other fan was here.. but its not working anyway. Ok .. biggest that will fit. Most cfms.
Their kit comes with. New sensor. On this engine. 4.0l there are 2 just under the throttle body. From what I understand, one is the the gauge, one is for the ecm. Any idea which is which ? I do have the full complement of shop manuals. Stufs not always easy to find .. and I suppose I can ask champion.
snoranger
Professional money waster
ASE Certified Tech
13,677
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
The one with the single wire is for the gauge. The one with 2 wires is for the ECM.
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Also might wanna run a diode off the AC compressor to kick the fan on when Air conditioner is on.
franklin2
1,768
Virginia
You need to find a new spot for your sensor, or sacrifice your gauge sensor(not much of a sacrifice in my opinion). You obviously can't get rid of the ECM temp sensor.
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
I spliced a fitting tube into the hose. They sell all the sizes cheap on fleabay and whatnot.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
I just ordered one for my truck. I went with a 3500 cfm kit that has a shroud instead of mounting through the core.
sumncguy
18
Hillsborough NC
at least 6"
32x11.5x15
sumncguy
18
Hillsborough NC
at least 6"
32x11.5x15
The A/C doesnt work anyway .. so Ill probably wire directly to a 12v engaged when the key is turned on. Just have to find something I can use. It does get hot her in NC but Im not in the truck all that much .. as I mentioned .. its my cheap g work horse around the house. I live in the country .. so you know .. garbage dumping .. Home Depot pick ups .. occasional towing of my bikes.
sumncguy
18
Hillsborough NC
at least 6"
32x11.5x15
How was the install ? Pretty easy without much modification ? Direct bolt on ?
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Haven’t received it yet. It’s still in transit. I’ll let you know.
Angry Possum
No Fat Chicks, Truck Will Scrape
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
Sometimes you eat the bear, sometimes the bear eats you.
I just replaced my clutch fan and put in a new radiator.l in my 4.0 OHV. I cleaned up my original fan. It cools nice now.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
I just replaced my clutch fan and put in a new radiator. Cleaned up my original fan. Cools nice now.
I did exactly this too. But I’m putting in the E-fan to try to save a tiny bit of fuels. I go yo sortta remote areas and try to carry another 5-10 gal but getting 5-10% better fuel economy will help some. Especially now with prices so dang high.
