For what it's worth- here is my 2 cents. In all my vehicles, I run manufacture recommended viscosity until the warranty is up. Then I switch to a higher viscosity oil. For my high mileages cars/trucks, I personally like the Valvoline 20W50 Racing oil for the summer, then run a high mileage 10W30 for the winter. Here in eastern PA, we don't usually get below about 0, so the 10W30 works fine. HOWEVER- I always let my engine warm up a few minutes in the morning, and never run it hard until things have warmed up well. Currently have a 91 s-10 with 236K miles, and a 94 Astro van with 220K. Both use less than a half quart of oil between oil changes at 4K miles, and have power and gas mileage almost as good as when new. Right now, I am running 10W40 in my 3.0 Ranger with 95K miles, and will probably go a bit thicker next summer. The zinc question is mostly important for us people with older engines running flat tappet camshafts, which puts a lot of shear on the cam, thus the need for a higher level of zinc (ZDDP) to protect the cam. Most (all?) newer engines have roller cams, and do not need as high a level of ZDDP. Diesel oils usually have a higher level of zinc than auto oils, and I have run the Rotella T 15W40 for many years in my 700 HP 66 Chevy big block and never have a problem. Also run that in my motorcycles. The zinc also provides start-up protection. ZDDP levels have been reduced drastically over the past 5-10 years. Please note that the link to the "bobistheoilguy" additive listing goes to a posting that is over 4 years old. Additives change all the time. Current spec for ZDDP in SM oil is a max of 1200 ppm, but even the synthetics are way below that, usually about 600. I have heard a lot about how zinc can ruin a cat converter, but have not been able to find any hard data on how much is too much, and if the engine isn't passing oil, does it matter if the zinc level is high? That's my 2 cents worth. If you are not sure, stick with manufacturer specs. Or, try a few things, and see what works best for your particular engine/climate/driving style.
