black_demon69
- Jun 30, 2013
- 142
- AZ
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0l
- 2WD / 4WD
- 4WD
3 re curing codes (it does take a little time to set them again)
P0300 FORD - Random Misfire Detected
P0303 FORD - Cylinder 3 Misfire Detected
P0330 FORD - Knock Sensor 2 Circuit Bank 2
truck is a 2005 f250 with the 5.4l 242,000miles
symptoms:
CEL starts blinking and it starts missing and has loss of power @around 45 to 65 mph smooths out after that
CEL stops blinking a few seconds after gas pedal is released.
seems to idle fine
fuel pressure w new fuel filter as reported by scanner is around 40 to 45 psi
previous owner has replaced
spark plugs
coil packs
injectors
ECU
air filter
knock sensors
Yes he was throwing parts @ it and I don't know what kind of trouble shooting if any he did..
I plan on checking compression and possibly doing a cylinder hold test also smoking the intake to look for Vac leaks..
some guidance would be nice and appreciated
symptoms:
seems to idle fine
spark plugs
coil packs
injectors
ECU
air filter
knock sensors
