Wet interior.
Eric Kropp
Prunedale CA
2.8
Hi, I have two Rangers, a 1983 and 1985. When it rains both of them get the floor wet on the drivers side. I am about 99% sure it is not the winshield leaking since I had the windshield changed in the 1983 and there was no indication of a leak there. I presume it is some where else and that it is chronic leak source.
Any Ideas?
Eric<><
dmanmccann
foothills, NC
FORD
4.0 SOHC
Maybe its something around your door, like bad molding or something...I have a leak in my ranger behind the driver seat just in the corner..and its not the 3rd brake light....
dbxtr3
I HAVE THE SAME EXACT PROBLEM.
I joined TRS today to find answer to my problem. I have a 1993 ex-cad 2wd 3.0 Ranger for a company vehicle. I was cleaning out the truck the other day and notice that under the driver floormat the carpet was soaked. I KNOW it is not a leaking windshield becasue I had it change the day I noticed the wet floor 2 weeks ago and it is still wet. (I put a space heater on a bucket with the door open blowing on the wet carpet and dried it out. Then it rained the other day and it is wet again with the new windshield.)
It can not be the door leaking because it is not wet near the door just under the pedals like it is running down the firewall onto the floorboard.
1987 DANGER RANGER
Great Bend Kansas
Dont feel bad I have the same problem, but its both drivers side and passenger side. I thank it could be where the wire harness cames through. There is a rubber plug on both the drive/pass on the front inner fenders. Its been to cold and rainy/snowy around here to try and figure it out. If I come up with something I will let you know.
novascotiabinder
2008 ranger 4x4 sport driver floor leak
I have the same problem.My 2008 ranger has a leak by the kick panel on the drivers side and the dealer cant find it with a hose.I find if I drive the truck at highway speeds the leak is there its pretty small but more of an annoyance than anything.any Ideas?
AllanD
TRS Technical Staff
135
East-Central Pennsylvania
1987... sorta
'93 4.0
On an 83-85 (other than one that spent it's whole life in NewMexico
The likeliest source is a rust through somewhere in the cowl.
You probably don't want to hear that, and it's apparrent that nobody else wants to tell you, but there it is.
AD
97fordrunner
9
New Richmond, WI
I had the same problem all you are having with my 91 reg cab, i got bored one day and stripped the whole interior out and most of the dash and found some rust up under the dash not from the windshield but more the cowl and it wasn't cool, ended up scrapping the carpet cause it went to long without being noticed and I ended up spraying in the good 3m bedliner spray and tryed cleaning up the rust and re-sealing the hole. worked for the most part
preflight
HAmilton Ohio
FORD
2.3L
Look between the windshield and the hood where your wiper motor is dump lots of water in that area to find where its leaking. if that is where the leak is .. i used pop cans cut top and bottom off split the can open then place over the rusted area and a can of bull tar messy stuff
mkpecor
black diamond W.A.
ranger 4x4
2.9
its the calking in your rain gutter or your fire wall were the seem is,look in the vents by your whipers its probly full of crap take your fenders off and clean it out with the hose,or next time it rains fill around on the roof of your cab from in side, like in the corner by the top left side of windsheild,
garyl
Houston, tx
2.3 4 banger
might check the rear window, i have the same problem and i have feltthe carpet on the back wall and it was wet
Black P-38
Oregon Coast
'91
Rover 4.0 Aluminum V8 swap
I have the same problem with both the 86 and 87 Rangers I recently bought for my 5.0 swap. After ripping out the bench seats, rubber mats, jute pad and as much of the soaked foam and firewall covering as I could I am 99% sure the leaks are caused by the Large diameter rubber "grommet" on the main wiring harness where it passes through the firewall.
Both trucks have ill fitting grommets that can be moved around pretty easily revealing the edge of the hole through the firewall. When it rains I can see the drips, more like a small stream of water coming in at the harness.
I also took off my wiper access cover plates to clean all the dead soggy leaves from the cowl area and make sure water would drain. I ran the hose full blast into the cowl through the upper slots and watched the flood of water run out at the drivers side fender. There was no leakage into the cab so I'm sure its the grommet.
A car builder I know suggested cleaning/drying all surrounding surfaces and re-sealing the grommet into the firewall with urethane windsheild adhesive. I haven't done it yet 'cause I dont have a garage and it rarely stops raining here. He told me NOT to use silicone sealer.
The 87 also has a slight leak on the passenger side which appears to be from the computer harness grommet. I think the rubber dries out and shrinks just enough with age to allow these things to leak... badly. The padding under the rubber mats on both trucks, (drivers side), were flooded with water and when I pressed my hand against the firewall covering it was like a big wet sponge... YAY... :(
Gotta love workin' on OLD stuff...
Mike
skyjacker
Mission B.C
same problem here guys , its not the winshield its the pinchpoint behind and beside the windshield , water gets in there and rust forms , even if you replace the windshield it will start leaking again because the sealer wont bond to the rusted areas properley , only way of fixing it is to replace the rusted parts which is pritty pricy unless your a body man , anyway hope this helps ya'll out
