Vulcan vrs Durateck 3.0
8,372
No one called you a liar, I don't think you had the intent to deceive anyone, you just misinterpreted some information
Many engines share a common bellhousing pattern, Small Block Windsor pattern was used on close to 20 different engines over the years, V8's, V6's, and I6's
But the Vulcan V6 and Duratec V6 do not share a common pattern with each other
Transmission model does not denote what it will bolt to, just tells you its internal structure or version
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
One casting of the 4.6 block has a bolt pattern that matches the Duratec 3.0.
The FWD version used in the Lincoln Mk VIII, which is just a fancy V8 Taurus, was mated to an AX4 trans, and used the Duratec pattern. I ran across a thread on a T-bird forum that documented this quite well. It was about trying to 4.6 swap a Fox body T-bird, and the guy was very confused because he had read that the early 4.6s used the SBF pattern, and he had a 4.6 from a Mk 8 that he wanted to use for the DOHC setup, and a 5.0 trans, and they weren't even close to matching, but it also didn't match the later metric pattern from his brother's 4R70 trans.
i thought the Mark VIII was rwd based on the thunderbird???
88workcar
49
Pierre Part La.
Ranger XL
The more and more that I research, my original thoughts in 2014/15, before I ever had another Ranger was to swap a 2.3 Eco and trans. into a Ranger. I think now that I have been digging around and seeing the potential of the 2.3, the weight, ect.... It is indeed the very best choice for a swap. I can get it turn key..
Jason Johnson
70341
985-519-0367
52k 2015-2017 FORD MUSTANG ECOBOOST 2.3L ENGINE AUTOMATIC AUTO TRANS 6r80 KIT stk 1273
Drivetrain $4249.99
Run Pallet $850
Ship: $ 525 to your local old dominion freight terminal. The run pallet is to big to unload without a forklift.
Total $5624.99
https://youtu.be/MFFAX6F8yQs
The Master kit includes:
· Coyote 2.3L with engine cover and coil covers
· Exhaust manifold/TURBO and oxygen sensors
· Alternator
· AC compressor
· Engine starter motor
· All front engine pulleys and idlers and belts.
· Coolant tank
· Coolant lines
· 6r80 6 speed Auto transmission
· Auto trans shifter, and shift cable
· Airbox, mass air meter and intake hose
· Engine injector and sensor wiring harness
· Engine computer wiring harness
· Dash wiring harness
· Body wiring harness
· Body control module (power distribution block for the interior)
· Main Computer/PCM/ECU
· Under hood Fuse box/power distribution box
· Brake booster and master cylinder
· ABS module
· Brake pedal assembly
· Drive by wire gas pedal
· Matching Speedo/Gauge cluster
· steering column and key
· Fuel tank, pumps and module
· Abs Module
· Driveshaft
· radio bezel with push to start button
fastpakr
2,837
Roanoke, VA
88workcar
49
Pierre Part La.
Ranger XL
I think the price is fair for what all you get, no hunting, no pulling parts. Sent to your door.
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
@adsm08 m08is it possible you have a link to this forum???
17,907
SW Iowa
Jason Johnson
70341
985-519-0367
Drivetrain $4249.99
Run Pallet $850
Total $5624.99
· Alternator
· AC compressor
· Coolant tank
· Coolant lines
· ABS module
· Abs Module
· Driveshaft
2.0EB swap has been done, I think 2.3 would be similar.
I think the thread was at TCCOA, and IIRC it was part of a discussion of the 4.6 DOHC vs the Cobra engine. I can't find the thread right this minute, it's been almost a year.
Sorry, you're right, it was the Continental that was based on the Taurus platform and had the transverse 4.6.
That might be why I can't find the thread I was looking for.
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
i ask, because i have, in my possesion, a running Continental with the 4.6, and a non-running Ranger with the Vulcan 3.0. i know a lot of intake stuff and computer stuff will have to be done, i just want to know IF it can be done.
fastpakr
2,837
Roanoke, VA
Even including the thread ADSM mentions, I don't think there's been any indication of a -Vulcan- pattern 4.6.
Nope, I am 100% talking about a Duratec pattern.
Like I said before, the LS transmissions are the only way I have ever found to put a 3.0 DOHC in a RWD application.
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
someone mentioned ,in a different thread, (rusty maybe?) about the Continental4.6 having a more narrow(?) bolt pattern than the other ones, because it mates to a Taurus trans. I was just trying to dig a little deeper into that and see what I could find.
fastpakr
2,837
Roanoke, VA
Didn't we go down this road before?
https://www.therangerstation.com/forums/index.php?threads/different-bolt-pattern-4-6.179573/
Also...
You're referring to this thread:
https://www.therangerstation.com/forums/index.php?threads/rejuvinating-project-outrangerous.179340/
