Since i flip, i have a vibration problem between 40 to 50 mph. Is somebody can help me with that.
Personnaly, i think may be its my drive shaft angle that cause that vibration.
You need to make sure your pinion angle is set correctly. It needs to be equally opposite to your trans angle...for example, if your trans is angled down 6 degrees, your pinion needs to be angled up 6 degrees. If it's off by a lot you WILL get vibrations, ask me how I know. You can fix this with either angled leaf shims or by cutting your spring perches off and welding them on in a different spot to correct the angle. If you still have problems, it could be a bad u-joint, tires out of balance like mentioned before, and a few other things.
DRAGGINASS said:
i would tell what mine does...but i cant get my damn shackle bolt out....can u guys help at all???. i got the nut off but the bolt wont slide out...i used 2 diff impact guys tried hitting it out...wont move...i evan unbolted the drive shaft an tried slideing 2 one side on an lifting over...didnt work..lol what can i do??? sorry i couldnt help ya
The bolt is probably rusted to the steel sleeve that is inside the bushing. Common problem. Cut the head of the bolt off and pound it through. You need a new bolt if it's that bad anyway...so don't be gentle with it.
