- Jan 29, 2010
- 649
- Central Indiana
- Ford
- Engine Size
- 3.0
It was pretty common to see people with underdrive pulleys and high electrical loads experience things like dimming lights since the alternator was slowed down by the crank pulley. So, if you have stereo stuff, extra lights, an efan that is triggered when the AC compressor runs, or a combo of those things then it's possible that the charging system wouldn't be able to keep up with all of that.no....not an opinion.
not even close to an opinion....if it was a guess or opinion i would have had little doubt left to imply it was more then a guess built into the statement.. or at least attempted to.
your alternator is either fawked up or it has the wrong one installed. or the fan is fawked up and drawing 70 amps or something.
last sytem i checked in a 4.0 truck with everything on...high beams, blower motor ect was drawing 50 plus amps. so 80 plus with a huge e fan.....well within the capacity of a stock ranger alternator. they can make 90 amps at idle....there is some variance....but 95 amp is stock....upgrading to a 130 is cake.
pretty much everything 1/2 ton and down has an electric fan now....specifically due to efficiency.
and i went to efans only around 97 after dismal performance for a few years from mechanical cooling in my v8 ranger and most v8 conversions to that point i did. depending on use, the electric fan really shines... for some it wont matter at all....for others it is a worthy investment. just depends on how its used. ones actual drive cycle will prove out any gains, but theres no loss when installed correctly to say the least...
since 2008, my personal truck contains over 6 liters of diesel power with a smaller alternator then yours and biggest e fan ford makes cooling it for hundreds of thousands of miles.
so.
not realy an opinion.
Personally, I never had an issue with it, but I rarely used AC and didn't have any extra electrical loading other than the e-fan which was only triggered by coolant temps. For awhile, some vendors sold smaller alternator pulleys to compensate and keep alternator speeds at their factory levels.
