Transmission mount bolts stuck in place
RustRatz
22
Arkansas
Ford ranger
My 97’ ranger’s transmission mount crossmember bolts are stuck in place. The nuts came off, but the bolts are stuck in place. I’ve tried heating them up, beating them with a sledge hammer, and all sorts of other things. I just can’t get them free. Also tried cutting the bolt but I don’t want them to get stuck.
I have a new crossmember if I need to cut the old one up.
franklin2
1,769
Virginia
Bronco II
They won't turn with a socket and breaker bar with a piece of pipe on it? No impact gun?
Josh B
1,988
Oklahoma
Take that socket on a breaker bar and put all you can get on it. While you hold it there with all you can get hit it with a good size hammer
RustRatz
22
Arkansas
Ford ranger
Tried with a Milwaukee impact, and it just doesn’t move
RustRatz
22
Arkansas
Ford ranger
I’ll see if that works, but I don’t know if it’ll work
Josh B
1,988
Oklahoma
I don't know what kind of room you have in there, but with a bit of room and a solid blow to the socket it can coax one along
