Found! Toyo Koygo 5 Speed 4WD
TexasDuck66
U.S. Military - Active
33
Cleveland Tennessee
Ford Ranger XLT
Stock LIft
None
235/75/R15s
Hey there, I am in search of a Toyo Koygo 5 Speed with a 4WD tail housing for my 83' 2.3L 4x4 with a TK4 and I just wanted the extra gear so I can travel to Tennessee and back when I go on leave from the military during holidays/vacation.
franklin2
1,779
Virginia
Bronco II
Here's a place in Tenn that say they MIGHT have one.
1984
Transmission Assembly
#258 NEED TO MATCH 4X4 MT
999,000​
C​
LAKEWAY
$Call​
Strange Auto Parts & Salvage USA-TN(White-Pine) Request_Quote 1-800-445-2091
TexasDuck66
33
Cleveland Tennessee
Ford Ranger XLT
Stock LIft
None
235/75/R15s
fastpakr
2,849
Roanoke, VA
Have you considered a Mazda transmission instead?
franklin2
1,779
Virginia
Bronco II
I thought about suggesting that, but he will have to convert to the internal slave, different flywheel, different clutch. Something to consider though.
fastpakr
2,849
Roanoke, VA
Either way there is a shopping list of parts to swap over. Mazda adds a few, but it's much easier to find and stronger.
TexasDuck66
33
Cleveland Tennessee
Ford Ranger XLT
Stock LIft
None
235/75/R15s
It would be cheaper for me to find a TK5, which I finally did than switch over to a Mazda. I'd have to get a different transfer case, driveshafts, and probably a ton of other stuff.
franklin2
1,779
Virginia
Bronco II
By the way, isn't the toyo kogo a Mazda transmission? The later Mazda may be a different trans, but aren't they the same company?
fastpakr
2,849
Roanoke, VA
I've always been a little vague on that. There's definitely some relationship between the two. But like you said, the one we typically call the Mazda trans is definitely a whole different animal.
I'm not sure if the TK4 and 5 are the same length or not. If they are then it's an easy swap. If you have to swap around driveshafts anyway, I'd go with the newer trans every time.
